Question about Panasonic CQ-VD6503U Car DVD Player
15200217 diagram model wiring
Hi i need to know the wiring for this model the power,grd, audio
AMP GRD, WHAT DO I DO ALL MY SPEAKERS ARE DISCONNECTED
Hi p3rty8,
"Amp Grd" protect in other brand is an error code for short and overload. Once the power applied to the unit and shorts sensed by the processor the unit will automatically turned to "Amp Grd" to avoid further damaged to other parts. Most shorts is in the supply voltage (B+, Vcc) line and most common caused is the sound output IC (mounted in heat sink). This part is responsible for amplifying the audio from the pre-amplifier stage and will feed to your speakers.
If you have a knowledge in disoldering and soldering technique, I would advice you to pull-out this part and then try the unit. If the "Amp Grd" error code is gone then you must replaced this IC with a new one to back your unit in normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 23, 2011 | Car Audio & Video
Want to know what the colors are for the stereo wires
At this stage of the game(25 yr old car) make your own. Run 2 wires from battery (B+ and GRD) to radio. Make sure you put a fuse in the B+ circuit according to Radio's spec's. Install antenna wire in radio and if you don't know what color speaker wires are remove a speaker look at its wiring and locate them under the dashboard. If can't locate them buy some and install them. You need a B+ and Grd wire for each speaker from speaker to radio.
Sep 24, 2010 | 1985 Ford Tempo
Have a pioneer car radio model deh-p3100ub has power and good grd. it will not turn on is there a reset. fuse is good
do you have power going to both the red and yellow wires??? yellow is constant power (to retain memory) and red is switched (ignition). both wires need to see power before the unit will turn on.
Jun 11, 2010 | Car Audio & Video
My clarion cd player in my boat was working fine now it says amp grd. I have looked but i see nothing unhooked what can i do to get sound out of my speakers?
Remove all the speaker wires.
Power the radio back on and verify it is not the radio at fault.
If it powers up, check the speakers with a Digital Multimeter set to OHMS 20x.
Each speaker should have a resistance of 4 ohms. (or 8 in some cases)
Any variance (+/- .5ohms) means the voicecoil is blown, and replace that speaker.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
I got a stock ford JBL amp with no wiring diagram i need to know what wires are what i have tryed to test for the power wirer but no luck.
ok on most amps there are two sets of wire ports one for speakers & one for +12v,grd & 12v remote start if you look over each port it will say what port is for what wire if it is in a connector it gets slightly more complecated what you do is with a vm check from wire to chassis ground [like seat bolts] 12v with key off when you cet power isolate wire then turn key on till radio comes on then do the same test for 12v isolate that will be remote start then turn key off &check from the first wire to other wire for ground to find speaker wires connect a regular peace of wire to chassis grd & touch the wires you will here the speaker pop be sure not to hold the wire on long cause it will blow the speaker
Jun 04, 2009 | JBL BP1200.1 Car Audio Amplifier
Steam generator will not activate- thermasol model ASD300A
how do you know the unit has power?
what control do you have?
does it light up.
Mar 15, 2009 | Thermasol Steamshower Generator AF Series...
Need to know what the seven wires are coming out of Clarion Cassette player model # PH-890v that came stock on a 83 GoldWing motorcycle. The wires are Blue Green Yellow (about 18 ga. (I know the blue is...
The blue one is switched because it has no power till you turn the key on This setup is on a Gold wing motorcycle with a intercom it is an elaborate setup The yellow wire shows a momentary grd every time you test it then nothing, no grd , no power
Sep 03, 2008 | Clarion Car Audio & Video
Wiring diagram
Do you have any connectors left intact? All you should need is the alternator power, grd, starter, distributor power, advance
Jul 23, 2008 | 1986 Chevrolet Monte Carlo
No power turn on??
Does the voltage at the battery drop when you connect 12v to the remote terminal?
If not, there is too much resistance in the power/ground wiring.
If the voltage drops at the battery, either the battery is weak or the amp is drawing excessive current.
Dec 03, 2007 | Kenwood KAC-728S Car Audio Amplifier
Panasonic CQ-VD6503U Car DVD Player Logo
54 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
