Expert
- Posted on Mar 29, 2009
Re: I need help on how to replace bit on router craftsman...
You didn't state the model number. The older Craftsmen routers had a red lever lock on the top of the router, one position allows the spindle to turn, the other position locks the spindle. Here's the instruction for the older style routers:
- Unplug the tool.
- To lock the spindle press the red button in and slide it to the locked position.
- Unlock the height adjustment knob.
- Raise the router motor using the height adjustment collar until you can get a wrench onto the collet nut.
- Loosen the nut until it turns freely.
- The bit may still be locked in the spindle, tap it gently (not on the blade!).
- The bit will come loose in the spindle and can be removed.
- Replace the bit, tighten the nut snug but don't use excessive force.
- Unlock the spindle, returning the red lever/button to the free position.
- Adjust the height of the bit as you wish, then lock down the motor using the locking knob.
