Pentax Optio S5i Digital Camera Logo
Posted on Mar 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New sd memory card doesn't work in my digital camera
Have pentax optio s5i digital camera. works with sandisk regular 1gb sd memory card and with sandisk ultra II 1gb sd memory card, but just bought sandisk ultra II sdhc 4gb memory card and camera doesn't recognize it. when i turn power on, it stays on with blank screen, and no shutter action. won't power off unless i remove battery. any ideas what problem is?
  • nancsim Mar 20, 2009
    thank you
pontelemon
Level 3:
  • Master 538 Answers
  • Posted on Mar 19, 2009
pontelemon
Master
Level 3:
Answers
538
Questions
0
Helped
175910
Points
1223
It will not work with any "sdhc"
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
570
Points
Memori tidak bisa kebaca dan memori not formated ?
Can I use 4gb memory card in pentax optio s5i support
No. The S5i works with SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
2answers
Hi will a 2gb sd card work in a pentax optio s5i?
Yes it will but that's the limit. Don't go out and try use an SDHC card of 4gb and higher.
I put an 8GB microsd card (with an microSD to SD adapter) in may Pentax OptioX and when I open my camera, I have a short delay, then I receive an 'Memory card error'. What's the problem? Thank you.
The S5i uses SD cards. This means you can use microSD cards with an adapter. However, your 8GB card is actually a microSDHC card, which with the adapter appears to the camera as an SDHC card. SDHC cards are electronically incompatible with SD devices and will not work. You need to use SD and/or microSD cards, which max out at 2GB in size.
2helpful
Upgraded to Windows 7 & it no longer recognises my Pentax Optio S5i camera ? Cannot download my photos since installing Windows 7. Can we get updated software for my camera ?
HI there there try to download the windows 7 camera driver from pentax website. It will start work then. Another way is remove the memory card & put in in a card reader then you can also transfer all photos from card to computer For further help ask me . Thanks.
3helpful
Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
No the Pentax Optio S5i does not support an 8gb memory card.
8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
My S5i locks up if you put an SDHD card in.
The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
1helpful
Memory card
  • Supported Flash Memory: SD Memory Card Integrated Memory: 23 MB
  • yes you can used the memory card with this.
When Iturn it on the screen go blank and say card lack it is a pentax Optio S5I digetal camara
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Memory card size
The S5z is limited to SD cards, 2GB and smaller. The speed doesn't matter, but larger cards will not work in this camera.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
