Question about OKI C5400n Led Printer
Okie C5400 giving 162: Fatal Error
After changing the transfer beld on our Oki C5400n LED printer, its now displaying the error message: 162: Fatal Error. Does anyone have any idea what part of the printer is causing this error. The transfer beld is brand new and we've tried another one, yet, the error persists.
Posted by osvincent on
Karl Wright
    President:
  • 1,653 Answers
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Posted on Sep 11, 2009
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
How to fix error 491: Tray Empty on Oki c5400
printer oki b411dn put out of the balcony, unsatisfied by his work, too many error codes, to lost time, to failed
Feb 27, 2012 | OKI C5400 Laser Printer
Fatal error 020: oki c5450
As far as 020 error is concerned it is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Aug 18, 2010 | OKI C5400 Laser Printer
Need to know how to reset the oki c5400n to factory defaults
Procedure:
  1. Power ON printer while holding both the "+" and "-" buttons until “OKIUSER” message apear in LCD.
  2. Press ""+ or "–" button until “ENGINE DIAG MODE” is displayed
  3. Press "ENTER", will be displayed "DIAGNOSTIC MODE XX.XX.XX S-MODE"
  4. Press "+" or "–" button until “NV-RAM INITIAL” is displayed
  5. Press "ENTER" again
  6. Appear "TABLE 1" message
  7. Press "ENTER" until "EXECUTING RESET" message appears. "NV-RAM INITIAL" message will BLINK... IT resets TONER, DRUM, FUSER and BELT...
  8. Power OFF printer, wait 10 sec, and power ON again
To access Service Mode in C9300:
  • Power ON printer with 0, 1, 6, 7 at same time...
Nov 09, 2009 | OKI C5400 Laser Printer
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
Aug 26, 2009 | Office Equipment & Supplies
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Fatal Error 162
I am pretty sure this is the result for your 162 code:
When cyan toner sensor error has occurred
Try reseating your toner carts.
May 14, 2008 | OKI C5150n Led Printer
Fatal Error
Did you try cleaning the led heads
Apr 02, 2008 | OKI C9600hdn Led Printer
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
OKI C5400n Led Printer Logo
471 people viewed this question
Top OKI Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
