Question about Vehicle Parts & Accessories
Fog light switch problem
2007 hyundai Sante Fe fog light switch will not work.
Posted by larry diantonio on
Manni F. Bear
    New Friend:
  • 15 Answers
You should try not to mess around with it or try to fix it by yourself.take it to your best mechanic and ask if they know what to do
Posted on May 25, 2013
I DAMAGED THE CASING COVER ON MY FOG LIGHT, 2003 HYUNDAI SANTE FE, I WAS TOLD THE BULB COULD EXPLODE IF IT GOT WET FROM RAIN, IS THIS TRUE? MAAER
Explode ? No. Fail ? yes.
Cover the broken area with shipping tape and order a new lens from the dealer.
Jan 22, 2018 | Hyundai Cars & Trucks
What should I look for when my 04 Hyundai Santa Fe, when of the fog light does not work. Even when you put a new bulb in it.
IS THE SOCKET GOOD (ANY CRUD BUILD UP IN THE SOCKET) CHECK THE WIRES TO THE SOCKET FOR GOOD CONNECTIONS.
Oct 17, 2014 | 2004 Hyundai Santa Fe
Hyundai santa fe 2001 has no fog lights
I doubt if it is a serviceable part . I would just go to a wrecker that specialises in Hyundai and look for a car that was rear ended and get the part you want
Feb 02, 2014 | 2001 Hyundai Santa Fe
My hyundai sante fe is missing a cap where the fog lights go where do i get one?
Does the part look like this?
http://www.autopartswarehouse.com/details/QQHyundaiQQSanta_FeQQKC_HiliteQQDriving_Light_CoverQQ20012009QQK135605.html?apwcid=P1135867996W43b3f85c7ab9e&apwidh4Sn28N
Feb 28, 2011 | 2001 Hyundai Santa Fe
Fog lamp replacement
there is an access panel located in the wheel well,behind the fog light. it has plastic screw heads ,they don't turn out so just pry them out and u can reuse them . the fog light is now accessible
Nov 22, 2010 | 2007 Hyundai Santa Fe Limited
What is the best way to replace a fog lamp bulb on a 2008 Santa Fe?
1. Turn tires away from car
2. There is a plastic covering in front of the wheel that usually goes around the wheel well. There are plastic thumb pins on the outer edges of this plastic covering. Remove the thumb pins and this plastic piece will come off.
3. Behind this you will find access to your fog lights.
4. Then you can remove the fog light by twisting the plastic cover (if it has one) or by twisting the bulb
Nov 10, 2009 | 2007 Hyundai Santa Fe Limited
How do I replace fog lights on my 2002 Hyundai Santa Fe?
Look up into the bumper and see if you can access the fog light. The bulb should just twist out of the back. If not, the assembly should either pop forward or back to come out. I've heard though, that many santa fe's require the removal of the entire front bumper fascia just to get to the bulbs in which case you'd have to remove your headlights to get to the screws holding the bumper fascia on
Sep 09, 2009 | 2002 Hyundai Santa Fe
My 04 sante fe didn't come with fog lights and want to install some...can I use the same bumper without having to replace it? Wanna try to keep it looking factory without breaking the bank...Thanx
Yes , most all aftermarket fog lamps come with all you need to mount them depending on brand. The only thing you will need to do is mount them where you think you would want them.
Aug 12, 2009 | 2004 Hyundai Santa Fe
My 2007 Sante Fe fog lamp bulb went out and I wasn't able to
Step:
1. Turn tires away from vehicle
4. Remove/Replace just like an ordinary head light.
Jul 17, 2009 | Hyundai Santa Fe Cars & Trucks
2007 Hyundai Santa Fe - Replacing fog light
hi have not had pleasure of this on santa fe yet? but will try to help dependant of which side o/s or n/s ? i would first remove the screws holding the front of the under engine plastic cover/shield and drop down sufficient to gain view/access? to the rear of fog lamp then if a cover is on? try turning anti clock to remove? or if rubber cover pull off? then the bulb and clip should be visible? unplug the wire from bulb then the spring clip holding bulb in place normally just sring the 2x top ends together and swing down/clear to remove bulb? refit new bulb correctly! pay attention to position old bulb positioned? then clip securely and re connect wire at this stage it would be best to ensure bulb works ?? before you re assemble all else? wish you luck and hope this helps with your problem ?
Oct 28, 2008 | 2007 Hyundai Santa Fe Limited
Vehicle Parts & Accessories Logo
123 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
