I was doing a system recovery,by the time I got to the third cd it stopped. Something was the CD was damaged.now I am stuck on the windows boot manager screen. My status is 0x000000f. Can you you please help me.
1. Restart the Acer Aspire netbook by pressing the "power"
button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL"
keys at the same time.
2. During startup, hold down the "F8" function key
immediately when you see the "Acer" splash screen and the option for entering
"Setup."
3. Keep pressing the "F8" key until the "Advanced Boot
Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire
and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode"
selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the
Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode"
selection.
The Windows operating system will now start in "Safe Mode"
and you can perform a system restore or make needed changes to get your Acer
Aspire to boot normally again.
SOURCE: CANNOT BOOT WINDOWS XP ON MY ACER ASPIRE ONE LAPTOP
hi..if u have a Windows XP installer just put in the CD/DVD player then auto run the win XP and make install the new windows/OS and make a choice leave the current files if you to re cover the files using a new install OS/Windows..Good Luck and Have a Nice Day...
SOURCE: ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
SOURCE: Acer Aspire 5610
You are still in warranty, so call Aspire at (800) 816-2237 for live help. If the "helper" doesn't address your problem, or just tells you just tells you to reinstall everything, demand to speak to a supervisor. It's their problem, not yours. They are open until 5:30 PM CST
SOURCE: error 0000218 cannot load the hive; \SystemRoot\System32\Config\Software
try tossing your piece of crap computer onto a very hard surface...laugh as it cracks open..**** on it and then poop on it. Take a picture of it and send it to Dell. at least that will make u feel better. Roony C.--Cleveland
SOURCE: Acer Aspire E571, stuck on "ACER" screen
Have you tryed unplugging the HD and seeing if you can access the cmos?
To start the system recovery:
In
this case, first you have to enter setup by pressing F2 at boot time,
as soon as the ACER logo appears in the screen. Then, you will need
to switch the SATA Mode to IDE from AHCI.
Select:
Main -> SATA Mode -> IDE
This
is done to allow Window XP to see your SATA.as an IDE disk and
install the system.
When
you get the external USB CD/DVD driver to use with a Windows XP
installer CD, connect it to you laptop, switch it on and press F2
again to enter Setup.
This
time, scroll over to the BOOT menu and press Enter. Scroll down to
the last option USB CD- Rom and then use the F5 key to move it to the
top of the boot list order. Then press Escape and then F10 and finally Enter. The computer will restart and load the CD and you can start
the installation of Windows XP.
Hope this info may help you!
