Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Logo
Question about Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven
Frigidaire oven door glass clean inside
There are vents in the top of the oven door which allows grease,water etc, to go down inside the oven door. How can I take it apart to clean it>
Posted by suzi oliver on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
Posted on May 31, 2013
4 Related Answers
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
    Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
    Tools needed: good Phillips head screwdriver or small quad bit driver.
    B. With door in broil stop position lift door assembly off hinges.
    Posted on Aug 17, 2012
    Anonymous
    • 107 Answers
    SOURCE: Spills in between glasses of the oven door.
    The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
    Posted on Mar 25, 2009
    Anonymous
    • 550 Answers
    SOURCE: Frigidaire Dble OVen Model FEB30T6DCC Stainless (electric
    This exploded diagram of the door should help you get it apart, 4eb927f.gif It is going to be shrunk by the forum software, the full size image is
    here http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=FEB30T6DCC&mfgModelNum=&fkMfgID=4
    along with a full list of parts should you need them
    Posted on Sep 23, 2008
    Anonymous
    SOURCE: Burnt marks inside glass oven door
    stain is between glass in oven door. can we take door apart
    Posted on Dec 17, 2009
    2answers
    How to clean inside glass oven door
    Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
    5helpful
    2answers
    2helpful
    Oven door window has streaks
    you have to let the oven dry and clean and you should not put any oily foods on it..
    GLASS BROKEN ON MY FRIGIDAIRE PRO
    Inner or outer? you will have to take the door off, done by lowering door to full open postion and youll see a fold down flap at hinge, fold down and close door and lift. this will allow you to access screws easier. remove handle and four bottom screws. that will allow you to take off outer glass....there will be screws on inside to take out inner glass.
    Grease in between glass on oven door
    You have 2 pieces of glass that are separated by a frame then sealed. What has happened the seal has been broken and thus allowing air and grease inside. You can take it apart but the grease will come back, or you can buy a repalcement glass and be done with it. The question is, do you want to go to the trouble of cleaning the glass (1-2 hours of disassembly and assembly) probably once every 2 months depending on how often you use the oven, or buy a new one and it will always be clean. One caution, cleaning the glass periodically weakens and flexes the metal frame or band thus making it harder to properly seat the glass.
    2answers
    Cleaning between double glass oven door
    Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
    Feb 04, 2009 • Ovens
    Dirt and grease between glass in oven door
    i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
    any ideas jimmy
    Aug 01, 2008 • Ovens
    Top Frigidaire Ovens Experts
    Marvin
    Marvin
    David Shaub
    nu267
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
