Question about Hasbro Nerf N-Strike Raider Rapid Fire CS-35 Dart Blaster - Blue
How To The Nerf Raider CS 35 Mod Tutorial AR and Safety Removal Jam door...
You can our can refer to this
Posted on Nov 09, 2014
Jun 24, 2014 | Canon Service Manual For Ir 600
Mar 04, 2014 | Oki Electric Industry C530DN Led Printer
Sep 25, 2012 | Panasonic Workio DP-6010 Toner 35 000...
The drum and toner
can become stuck in the machine if the develop joint link is not attached
properly.
1. Open the front
cover.
2. Remove the drum
and toner.
- If you are able
to remove the drum and toner, the issue is resolved.
- If you are unable
to remove the drum and toner, continue to the next step.
3. Looking into the
interior of the machine, there should be a plastic latch (develop joint link) on
the left side of the machine that is connected to the front cover (connector),
an inch left of the manual feed slot. This plastic latch is usually not the same
color as the front and side cover.
- If the develop
joint link (plastic latch) is there but not connected to the connector on the
front cover, continue to STEP 4.
- If the develop
joint link (plastic latch) or the connector on the front cover is broken, go to
STEP 5.
4. Pull the end of
the develop joint link (plastic latch) towards the connector on the front cover.
If the develop joint link (plastic latch) pulls out, pull it gently to the left
of the connector and then push it over the connector, securing it firmly onto
the connector. Remove the drum and toner.
- If you are able
- If you are unable
to remove the drum and toner or secure the develop joint link (plastic latch)
onto the connector, continue to the next step.
5. Pull the end of the develop joint link (plastic latch) towards the connector on the front cover. Keep the latch pulled out and remove the drum and toner.
Aug 31, 2011 | Brother HL 2270DW Laser Printer
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Nov 23, 2009 | Ricoh Aficio 1013F Copier
Nov 07, 2009 | 2005 Chevrolet Venture
Jun 16, 2009 | Ryobi Garden
Oct 31, 2008 | Canon NP 6545 Copier
275 people viewed this question
