Is this an easy fix that I as a non-professional can resolve on my own? This error code is displayed when I attempt to ignite the heater to warm up the Jacuzi.
If the Blower Prover switch contacts do not close after the
Combustion Blower is energized the Control System will lock out and display Blower Prover Open
Blower Prover Open
Fault occurred 2 mins ago
The blower prover switch remains
open after the blower has been
energized.
Call a service professional:
Your Company Name Here
(press [DOWN] for more....)
These plastic sensing tubes must be routed to the correct sensing ports on the water heater. Sensing tube
routing should always be checked whenever Blower Prover Open, Blower Prover Failure, Blocked Air
Intake or Blocked Exhaust is displayed on the Control System LCD, see Figure 31 on page 29. These "Fault
Conditions" can be caused by incorrect sensing tube routing.
Charlie
I too have the same AO error code when I try to use my Hayward H-series spa/pool heater. I placed a warranty call with my home warranty company, (thank god we covered the spa & pool equipment too) and when the electrician came out....it's the blower on the heater that has to be replaced.
i hear the gas then turns off with IO error
When turning on my heater to the pool it flashes AO? Can I fix this on my own?
I'm getting SF when I try to fire my heater. What is the cause
