Bought this fan used, need a manual for use and cleaning.
SOURCE: aloha breeze 52 white ceiling fan
Is there something specific you need to know?
Kill power at the breaker for saftey. Mount the bracket to the ceiling first. there should be a small hook on the ceiling bracket that you can hang the fan motor from while you do the wiring.
The blue wire and black wire on the fan should both be connected to the black wire in your house wiring. Attach the fan blades to the motor once it is in place.
SOURCE: Globe broken on Aloha Breeze 52" Satin Nickel - need replacement
try a hardware store, lighting store home depot. You'll likely find the globes are standard size.
You could also try Aloha Housewares 1-800-295-4448 9am - 4pm CST (Closed from 12-1pm)
SOURCE: Aloha Breeze Ceiling fan M# 29081, Fan Switch Problem
call 1-800-295-4448
you need a switch from them the internal mechanism is different. its free of charge
SOURCE: Need instalation instructions
I bought two of these(model 99328). Would be happy to send you instructions from one of them.
Where should I send?
