Im told that with this error I need to replace the motor pump assembly. I have done this and I still receive the same error as well as the dishwasher won't drain....please help
While LE is the LG error code for "Motor Error": The Motor is working
abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
