RCA E13320 13" TV Logo
Anonymous Posted on May 24, 2013
How do i unlock lost or forgen password.?v hold
Level 3:
Top Expert:
  • RCA Master 76,851 Answers
  • Posted on May 24, 2013
RCA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987045
Points
237762
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
2answers
Screen unlock password on budget mobile umx model #mxw1
If it is an Android phone the hard/factory reset will help. But all data will be lost. Switch off the phone, hold down the volume down key and the power button in the same time and keep holding both until it boots up. For more suggestions check this Can do hard reset of my UMX Max phone
Mar 16, 2016 • Cell Phones
2answers
Change email address @ password
You will need to update your email information with all of your online accounts otherwise you will have to use your old email address and old password to gain access. You can leave them the same, just because you've moved doesn't mean you have to change your email address too.
1helpful
2answers
PHONE LOCK PASSWORD
Did you mean carrier unlock password ? Have you lost already what you have bought ? No need to worry regarding this . If so, whats your mobile brand and model ? Just buy network unlock password from online service provider TheUnlockSpot.com to unlock your phone from sim lock .
Dec 05, 2014 • Cell Phones
2answers
How to unlock hp pavillion dv5 laptop
he following 3 methods are for your preference. Have a try!
Option 1: Use a password reset disk to reset lost password if you have created one before forgtting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live cd,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Unlocker, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Steps:
Step 1: Download and install Windows Password Unlocker in any available computer.
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storage• : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Lost password
Turn the volume down to 0 then change to a blocked channel. (where it asks for v-chip password) Next, on the TV, not from the remote, hold the volume down button, and hold the '0' key on the remote for between 2-10 seconds... the screen should unlock and you should have no V-Chip restrictions.
1helpful
2answers
Lost password to my t-mobile wing phone
hold down both soft keys and press the reset button
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
