SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
SOURCE: rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
SOURCE: rca 32v434t
Bought same television 32v434t from walmart went out after seven months rca sucks,having tv fixed but not under warranty if you people want to know what the prob is its a transformer and it also burns out some of the cicuit board on the horizontal having tv fixed the cost for me was $210
SOURCE: Hi, I have a RCA 61
try to resolder all bad cold solder and open ones
see if this helps good luck
SOURCE: rca truflat 13
Ur video board that connected to the CRT(tv tube)long neck.It needed resolders the board it have cold solders.U know how to solders, resolders the ssockets pins that the CRT video board connected to.
