Canon LC-3175 Laser Fax Logo
Question about Canon LC-3175 Laser Fax
Canon laser class 3175 manual
HOw do I print a activity report?
5 Related Answers
Anonymous
  • 2120 Answers
SOURCE: faxes in memory & will not print out
Unplug the power cord for 10 seconds
Posted on Nov 11, 2008
Anonymous
  • 66 Answers
SOURCE: I would like to retrieve an activity report from july 2008
Sorry... you can't
Posted on Dec 14, 2008
Anonymous
  • 121 Answers
SOURCE: Need fax confirmation
Not an expert on this model however, on most canon fax machines the plastic cover or panel on the keypad is a door. Opening this you should see descriptions for the keys one should say report. Press report to print and follow instuctions to get activity report.
Hope this helps
Posted on Mar 14, 2009
Anonymous
  • 318 Answers
SOURCE: how do you print an activity report from a canon
Press the funcktion button then the report button activity report will be displayed press set.
Posted on Dec 06, 2009
Anonymous
  • 114 Answers
SOURCE: Canon Laser Class 2050P fax prints solid black
try a new cartridge
Posted on Mar 19, 2010
Hello - We have a Canon Model 3175MS Fax Machine - we want to print a comfirmation that a Fax has been sent. Is this possible? Thanks! Marcy
Yes, it is called a `transmission report' (TX report), and is a setup option.
You can change this setting with the following procedure:
Open the 1-touch panel to access the function keys.
Press the `data registration' key to access the user menu.
You should see `user settings'. Press the `set' key. Press the cursor down key to get to `report settings', and press the `set' key. You should see `TX report'. Press the `set' key. Cursor down till you see `output yes'. Press the set key.
Press the `stop' key to return to the normal screen.
It is now set to print a report after each transmission.
5helpful
2answers
How to print FAX transaction report on Canon LC 9500
First you have to lift the panels under the speed dial numbers to expose all of the additional features and setting buttons, Press the REPORT button, then the SET button. This will give you a daily log.
2helpful
2answers
How do you print an activity report from a canon laser class 2050 fax machine?
Need instructions on customizing Transmission Verification Report
Terry,
Please send me your email address...I can send you the Facsimile Guide in PDF formatt pages 11-11 and 11-12 provide Tx Report Settings.
[email protected]
Hope this helps
Cannon laser 3175 ,after copies it print activity report
yes you can go into additional fuctions button then go into reports and turn off error reporting and activity reporting, or its under communication settings
Faxes in memory & will not print out
1helpful
2answers
Test Page on Canon FAX-L220
There is no test page for the canon laser fax, the only one is to print the report list. The report list of Activity Report you cant get it by pressing the [report] button and press [set] button or if you want others report like the User Data report, Tel Registration report then press the Data Registration and press [Set] and select by pressing the Scroll Up/Down button to locate the Report setting.
old marine
old marine
Marvin
Marvin
