Question about Garden
I have a cub cadet rzt 42 zero turn, it was running fine and I shut it off for a minute and now it won't start. When I turn the key it just clicks.
Posted by sthawk on
06 Dyna FXDI
    New Friend:
  • 171 Answers
Low battery voltage, not charging, or the starter relay/solenoid.
Posted on Jun 24, 2013
3 Related Answers
mike butler
  • 6468 Answers
SOURCE: I have a Cub Cadet zero turn RZT 50 that when I go up a steep incline and put the driving bars all the way forward it won't move. The back tires don't even spin. When it is on even ground it
being that each wheel has its own pump and motor the common connection is the belt it must be slipping and if its slipping without making a lot of noise look for oil being on the belt if so look for the leak the bottom of the engine crank seal is a common spot
Posted on Apr 27, 2012
Cade ivy
  • 7 Answers
SOURCE: cub cadet rzt 42 starts but wll not go into gear and run
Check the drive belt, if it has slipped off the mower wont move
Posted on Apr 18, 2013
Cade ivy
  • 7 Answers
SOURCE: My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
How can I determine which safety feature is not allowing me to start my cub cadet rzt 42 lawnmower?
You first need to find out why this safety feature is being triggered rather than bypassing it for your safety.
Jun 07, 2016 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
How do I ADUST the valves on my cub cadet rzt zero turn lawn mower???
you will need to take it to shop it is complicated to do
Apr 17, 2014 | Garden
Garden Logo
336 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
