We ran snake through the spray head and there was no blockage.
But the coffee that is being made is extremely weak and we have never had this problem before.
Hello. Have you checked your temperature of the water? If it is not hot enough, 185 to 195, it will not extract the coffee properly, causing a weak brew. Putting the spring through the spray tube does not necessarily clean the whole water brew system, and you could still have a flow problem to the sprayhead. You can check it, just pour in water, no coffee or filter, the funnel in place, a pan or something to catch the water, and while it is brewing, with a flashlight, pull down, or forward enough on the funnel to look at the spray head, there should be 5 or 6 streams of water coming out of the sprayer. If it is dribbling out, and down the sprayer, or not a decent flow from the holes, you still have a blockage somewhere. You can go here to get a parts manual for your unit, to see how things come apart etc..
http://www.bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
You may just need additional cleaning, if it is bad, it may require chemicals.
Hope that helped, and thank you.
