Question about Pramac GBW30P Encl Diesel Genset w/Perkins Eng
Diesel mixed with oil in the sump
After running the generator(40kva-perkins), oil pressure falls from 4 to 2 bar while oil level when checked in cold condition found to be too high and oil diluted, smelling of diesel within.
Posted by rkchandani20 on
Anonymous
    Problem Solver:
  • 11 Answers
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Posted on Mar 21, 2009
sherlywang
    Master:
  • 425 Answers
Ifesi
    New Friend:
  • 8 Answers
You should check your injector seals
Posted on Jun 03, 2011
  • Mk Ling
    Mk Ling Apr 13, 2015
    you should check your fuel transfer pump or fuel pump seal.
What size generator do I need to run a 10 hp motor
on the plate attached to the motor you will find several important items
one is the wattage of the motor
this is the maximum wattage that the motor uses when under load
the gen set will need to be at least 30% bigger than that figure
next there will the number of phases that the motor is
it will read as 1 ph or 3ph
If it is 1ph that is a single phase motor and will ru from a single phase gen set
however if it is 3ph you will need a 3ph gen set to run the motor
As most single phase motors are limited to around 5hp I would be very sure that the motor is not 3ph
specialist advice from an accredited electrician or electrical motor shop is recommended before buying a gen set. as if you need 3ph the gen sets become expensive.
Aug 07, 2015 | Electrical Supplies
How do i do when some genset can't run togheter when we start the plant
im not sure are you asking about Phasing ? on a three phase gen set , yes extreme care needs be taken if you need to start one genset before shutting one off , in this case a Phase/sync meter will need to be used to keep from surging all the loads connected to genset , also all three phases of each genset needs to be "In sync" to be able to use a transfer from one genset to another , in sync refers to peek waveform on each genset, needs to be in perfect time or an "ARC" will occur , that could be detrimental to the connected loads if there sensative to this type
Jan 18, 2015 | Electrical Supplies
Perkins engine 40kva , the engine is do in overheating ever time and have change the gaskt two tax why
Make sure all of the vents, on the engine are free of dirt. Check carb adjustment and adjust as needed
May 08, 2014 | Electrical Supplies
Perkins engine
Check oil is correct grade and topped up. If OK overhaul engine.
Jan 27, 2014 | Garden
Check engine light is on. Engine sounds like it's knocking. And oil light is coming on. This 2008 Dodge Dakota has only 63,000 miles.
Sometimes that light means overfill oil
Sometimes after changing oil if they put too much that happens
Check the oil level on cold in level place (give it like an hour or so) for the light to reset
If after that the light still on take it to a tech.
Good luck
Dec 20, 2013 | 2008 Dodge Dakota
Pramac 25 kva perkins encl diesel genset will not start red light on triangle on check list
Hello. Maybe you have solved your problems. But I still want to share the helpful article to you. https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
We are Perkins diesel generator OEM. Can provide 22KW to 2200KW diesel generator set with Perkins engine. https://www.dieselgeneratortech.com/perkins
Dec 09, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Perkins 20 kva diesel generator runs and stops in about 2 minutes.alternator failure is displayed on screen.
Ensure any engine control switch is set to the run position, with the load disengaged. Manually set the air shut off valve (if fitted) to the run position (see Fig. 18), Turn the key switch to the start position, which will energize the solenoid allowing the engine to crank over for a few seconds then start.
Check the instrument panel is showing normal running oil pressure, and the ammeter for charge to the engine batteries.
Allow the engine to run for five minutes checking the instruments are reading correctly. Stop the engine and check the oil and coolant levels, replenish if necessary.
https://www.dieselgeneratortech.com/generator-sets/normal-starting-procedure-of-Perkins-generator-set.html
Sep 28, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
500kva 380 volt diesel generetor
make sure gen isnt stopt on protection overtemperature or oil level or coolant level. try to bridge protections one by one to find the course. first make sure all fluids are on level and coolers are clean. fanbelt tension and coolantthermostat can also be wrong.
Jan 23, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
MY Perkins generator 2300 series crank but can not start
I take it it's diesel. Have you renewed filters? Bleed fuel system Make sure there is plenty of diesel flowing out of tank (pipe not blocked) Check lift pump working
Oct 22, 2009 | Electrical Supplies
Diesel generator runs for short time then shuts down. it is a onan 7.5 & runs off of the motor home fuel tank
More than likely a safety control circuit on startup. Either high water temp, low oil pressure, or over rev condition. If not any of the above quite possibly the integratrated generator/engine control circuit board.
Allan
Jul 20, 2009 | Electrical Supplies
Pramac GBW30P Encl Diesel Genset w/Perkins Eng Logo
719 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Robert Wooley
Robert Wooley
Ngoro
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
