QVS NetStar (UPS650A) UPS System Logo
Anonymous Posted on May 23, 2013
My ups is suddenly getting off even continuous supply is given to it.I am using same ups for 3years can any 1 suggest what is the problem??
Bill Boyd
Level 3:
Top Expert:
  • QVS Master 53,816 Answers
  • Posted on May 23, 2013
Bill Boyd
QVS Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949255
Points
172802
The problem will be in the battery in the unit. After 3 years the battery will be un chargeable the same as in the car. Batteries are available from most good battery shops . Take the unit in so that they can match it.
My machine konica minolta bizhub 164 copier, shows on display c3451, without taking any command,pl suggest?
Description
Warming-up failure
- The surface temperature of the fusing roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle.
Remedy
1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change PRCB. 6 Change DCPU.
Vizio P42 HDTV poor picture
Check the Vs & VA voltages to the panel. If found abnormal, try to adjust it to specified value. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Adjustment procedure to this voltage is similar to all plasma displays, and guidance to one brand can be taken as reference. Adjustments to this voltage is given by one among the posts. Details too are given with illustrations. The given details are for panasonic plama TV. Refer it. You's get an idea about this voltage adjustment. If you can't adjust it to proper value as suggested, the main power supply board need replacement. Even after replaced it with a new board, this adjustment should be done again. This is a crucial adjustment to all plasma TVs.
Vw sharan problems
I suggest you get one of those manuals people get nowadays to do it yourself.. Even My nephew use it to repair my car and it's totally repaired now. Here's the website he bought it from.
Best Manuals
PC will not start up all of a sudden. I see the CPU fan running and the power supply tester I used showed it was all right. The boot post does not even initiate.
Its very simple Solution.. simply open cabin cover and take ram out and clean ram slot and ram and wait for 5 min and reinsert ram into ramslot.. and switch on computer... if same problem continues repeat it 2, 3 times.. still problem continues contact me [email protected]
Sharp Microwave R218D 3years old, suddenly isnt heating up. There was no burning spell and problem noticed. But its not heating up. Even the Bulb is ON and its rotating. Please help
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Dishwasher not starting when door closes
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
1helpful
2answers
Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Shuttle83
System Hanging at any time
Dear Ramesh,
Have you ever change/update your RAM in recent time?
Power not turning on
Power supply failure! Requires several steps==
1)Pull main board & power supply board
2)Check horiz output xistor = shorted? Replace w/ first quality
3)Carefully solder horiz drive circuitry from HDT to base of o/p
4)On power board--replace shorted converter transistors 2SC4834 and R607 .1 ohm 1/2 watt fusible
5)reassemble.     Let me know how it goes.....T.
Top QVS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a QVS Computer and Internet Expert? Answer questions, earn points and help others
