Fisher Paykel Fisher & Paykel DishDrawer DD24DCB7 Semi-Integrated Double DishDrawer with 14 Place Settings, 9 Cycles, Eco Option, 163 Degree Sanitizing Temperature, Delay Start and Adjustable Racks: Black Logo
Question about Fisher Paykel Fisher & Paykel DishDrawer DD24DCB7 Semi-Integrated Double DishDrawer with 14 Place Settings, 9 Cycles, Eco Option, 163 Degree Sanitizing Temperature, Delay Start and Adjustable Racks: Black
F2 error code drawer
We have a dent in our bottom drawer - can we buy a replacement panel or do we need a whole new drawer? How much would it be?
Sam
  • Fisher Paykel Master
  • 3,247 Answers
In order to find the availability of spare parts for your model of dishwasher it would be helpful if you can provide the Product Code from the label on the front of the main unit.
Posted on May 24, 2013
1helpful
LMXC23796S Freezer drawer has small dent in it-is there a skin or is this whole drawer and cost on this part-thank you
ADD74236201 is part number u will need. Have to replace the whole door. Just type that number in sears parts direct. 130 bucks
NO POWER TO TOP DRAW
Not sure which model you have but if top drawer in double drawer has no power then it could mean a few things - either the thermal cutoff sensor has blown or the power board at the base of the dishwasher (under bottom drawer has blown). If you are not getting an F2 error on bottom drawer then more likely it is the thermal sensor. Not an easy job to fix as the whole heater assembly has to be replaced. The cutoff is integrated with the heater. The power board is easy to replace provided you have good handyman skills. ALWAYS TAKE OUT MAINS CABLE before working inside the dishwasher.
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Fisher & Paykel Dishdrawer: DD603: Have had motor & rotor assembly replaced - now F-2 code here is goes again. Determined to have husband fix it!! I hope. Company says it is an issue with the...
Hi - F2 error code indicates a failure of the rotor/motor or the sensors, the following notes should give you guys something to check and see which of these has failed..
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
The top drawer of our F & P dishwasher is showing and F2 fault, I have just fitted a new front control unit. F2 is the pump I believe, where on the unit do I find that?
The F2 fault implies there is a problem with the motor rotor which is located under the drain plate at the bottom right in the centre of the drawer. The rotor is actually driving the wash arms.
F2 does not necessarily mean you have to replace the rotor. It is also possible there is some debris inside the rotor cavity which is preventing the rotor from rotating at the normal speed.
Remove the racks and the wash arm. Twist the centre ring so that it disengages the drain plate. You can then pull the rotor out with a few back and forth twisting motions. Check if the cavity is clean. Re-insert everthing and start the wash cycle. If F2 comes in again, you will have to eliminate the cause by using the rotor from the bottom drawer and see if it makes any difference. You may then have to buy a replacement part.
good luck
2answers
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
2answers
I have a f1 come up and a f2 on my dishwasher what is it
f1 = Flood Code
This means that the dishwasher most likely has a leak
There is a float switch in the bottom of the machine and when water gets down there it trips the code
F2 = Roter not moving
you can remove the basket and spray arm and pull the roter out and make sure its clean and give it a try.
2helpful
There is an error code f2. How can I fix this?
The F2 code= siezed pump. To check remove all the dishes followed by the grey dish wrack wedged in the bottom. Lift off the plastic spray arm to reveal a grey plastic ring around the outside of the stainless mesh, and you will also see the blue plastic impeller. Turn this anti clockwise and lift out the whole stainless mesh cover. Then there is a brownish ring with the blue pump impeller on top. Turn this anticlockwise and the pump should lift straight up and out. The impeller may have come off and lifted off with it the brown ring leaving the rest of the pump stuck in the hole. So be careful here, get it out without damaging the housing it fits into. Replace the motor/impeller unit and off you go. Yours could just be stuck of course. A clean may do the same trick.
Feb 16, 2010 • Dishwashers
Open Questions:
See all Fisher Paykel Fisher & Paykel DishDrawer DD24DCB7 Questions
Top Fisher Paykel Dishwashers Experts
Marvin
Marvin
mark warfield
mark warfield
Are you a Fisher Paykel Dishwasher Expert? Answer questions, earn points and help others
