I'm installing a new Pioneer MVH-350BT but it loses all memory when the car is switched off. I understand this is a problem with the 12v constant wire but I don't know which one to change. The yellow is marked 12v+ constant but it seems to be connected properly from the unit to the ISO block. Very grateful for any help.
Hello sorry for my English
Look it's very simple and easy to fix ok
Just take off ur radio and then u well see 2 cable 1 Reed color and the other one its yellow. take off the red one and put it en instead the yellow and the yellow instead the red and the problem its resolve
Sorry again for my English
SOURCE: wiring diagram
Try here:
http://cgi.ebay.com/Pioneer-FH-5071ZM-Car-Tuner-CD-Player-Service-Manual_W0QQitemZ290221309136QQihZ019QQcategoryZ39996QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
SOURCE: wiring a used pioneer deh-p630 date mfd. june 2001
blue/white is an amp turn on wire it is only needed if you have an aftermarket or factory amplifier in the car. It can also be used if you have a power antenna and there is not a power antenna wire in your harness. Yellow/white I don't recall ever seeing in a wire harness are you sure it is not orange/white? If it is orange white then it is a dimmer and you could hook it up to orange white on your harness or just cap it off and leave it alone. The yellow wire is your 12Volt constant power wire. This needs to go to a constant source of power and the red wire needs to go to a switched source of power. If you do the power wires wrong you will drain you battery fast.
SOURCE: How to wire KD-S741R CAR STEREO - WIRE COLOURS ???
older pioneers:
2 x green (1 with black tracer) left rear spkr (black= negative)
2 x white (1 with black tracer) left front speaker
2 x grey (1 with black tracer) right front speaker
2 x purple (1 with black tracer) right rear speaker
Lower connector
1 x red ignition (switched supply)
1 x blue antenna output power (may not be not used)
1 x yellow Illumination (radio button lighting)
1 x orange permanant Battery supply
1 x black vehicle GND
If still not working swap yellow and orange wires! will not cause damage
SOURCE: no memory on alpine ida -x305 head unit, correctly
Hi Terry
I know you say the yellow wire is the constant live but on some cars you have to wire the red and yellow as one, what make is the car?
Regards
Dan
Testimonial: "hi danni my car is a citroen xsara 01 model have tried the yellow and red both to live but no luck ,looks like i have a duff unit terry."
Take off ur radio
U will see loads cable's
Look for the yellow and red cable's
Change the cable's the yellow instead the red and put the red cable instead the yellow that's it
Hope help
