Toshiba e-Studio 350 Copier Logo
Posted on Mar 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Feeding paper for scanning/faxing - e-studio350
Our feeder doesn't grab the stack of papers well, while trying to scan multiple pages. Is there an adjustment setting on the machine or do we need a replacement part?
Thanks,
John
didi2005
Level 3:
  • Toshiba Master 727 Answers
  • Posted on Mar 19, 2009
didi2005
Toshiba Master
Level 3:
Answers
727
Questions
Helped
428453
Points
1454
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
2helpful
3answers
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Xerox documate 752
Your document must be in place/position to be scanned, faxed, etc.
Place document, then scan. ADF is your automatic document feeder. Used when copying/scanning multiple pages. Reload and try again.
Pulls multiple pages when sending fax
Problem :
feeding paper
Solution :
Clean in the feeder section all the rubber pads that pull the paper with alcohol
1helpful
Paper is not feeding into the top.
I also was not able to copy, scan or fax multiple pages through the ADF of our HP Officejet 7210 AIO, but it would print well from the computer.
It would either grab several pages at once, or not grab paper at all. The device was trying to work but had poor traction action. Not sure if that's the same issue you are facing, but if it is, this is what fixed my 7210: I purchased part number C7309-60091 which is the feed roller assembly, and part number C7309-60076 which is the separation pad from Encompass Parts, and replaced them. The ADF works great now. The HP Officejet 7210 had only 5,000 pages printed on it, so I chalked it up to our very dry atmosphere here.
1helpful
Paper jams when trying to fax or scan document
Check if the ADF backing is tucked under the the ADF frame. You can view here http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf steps 7 & 8 on page 155.
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
HP Office Jet 7310
chances are the feeder isnt feeding the paper at all, thats why you cant scan a single paper, try opening up the ADF and clean the feed rollers first, turn off the machine and gently rub the rollers again and again until you have a clean shot or surface, try this from thop to bottom rollers, please make sure though to insert uncreased paper and paper without eardogs on its leading edge, this could cause some delay upon feeding process
sometimes because it is exposed to dust, there is a tendency for the rolllers to slip, or you could be having a broken part that drives the feed rollers from your ADF.
Muratec F-520
It could have something to do with the automatic document feeder. There could be something in there that is blocking the paper from feeding in there correctly. It could be the feed tires or the belt as well in the document feeder.
It should be looked at by a technician in your area in case there are some parts that need to be replaced.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
