Technically, the television should protect itself from doing any damage, but sometimes that doesn't happen correctly.
When you say that they sound like the speakers are blown, can you describe that sound?
If it sounds like they're blown, they likely are. It's probably about the same cost to repair the speakers (if out of warranty), than to buy an external amp and speakers.
In that case, it's probably not a completely blow speaker set, just one of the woofers (that does low end dialog)
You may be able to adjust your audio settings and turn the bass down a bit, and that might make it more watchable.
If not, it's not a very expensive repair to fix the woofer in a television.
When women talk it is fine but a mans voice makes it vibrate a little Kinda sounds fuzzy.
when i turn the tv on the speakers sound off a static noise
