Question about Samsung SGH-d807 Cellular Phone
Puk disabled card blocked
Ch:20700 data:usb daig:uart2 hw:w139.06 sw:ef26 y un: 0711021057433 f09
5 Related Answers
Ekse
  • 13434 Answers
SOURCE: puk disabled card blocked
if you have entered the puk code wrong around 10 times you have disabled the sim card, you can cut the sim card into peaces and throw it out from the window since you will have to contact your phone service provider for another sim card or if you have prepaid buy another set.
before throwing the sim card away I suggest you contact the service provider to see if they can help you. if the card isnt blocked yet.. or if you can still enter a puk code you might be able to fix it by calling the provider and getting the correct code if not, its useless card.
Posted on Jan 02, 2009
Anonymous
  • 3422 Answers
SOURCE: my phone keeps saying PUK Disabled. Card Blocked. Whats that mean
HI,
The only way to fix this issue is to contact your service provider.Only they can help you enable it.
IF you need any more help let me know.
Posted on Feb 10, 2009
Ekse
  • 13434 Answers
SOURCE: i have a samsung u600 showing puk disabled card blocked
Hi your only option is to call your phone service provider, no it doesn't come with the phone and the phone never has its own puk code becouse the puk code is about the sim card.
if you put in another sim card the phone will work just fine, its the simcard 3 times pin code wrong puk code enabled pin blocked, call service provider to get it and entery instructions.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 06, 2009
Anonymous
  • 81 Answers
SOURCE: PUK disabled card blocked
It sounds to me like your phone is network locked. You need to contact your previous carrier for a PUK key to unlock the handset. You may be charged a fee for this.
Posted on Jul 28, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: my phone says puk disabled card blocked. what should i do?
The PUK enters when a wrong PIN code is entered three times.
The only ways to unlock PUK are:
Finding PUK code printed on original phone or SIM card documentation.
Calling the SIM card company and getting PUK free of charge.
Replacing the SIM card.
The PUK is linked to SIM card not to phone. To unlock you can look for SIM card phone company website, then contact them by phone.
Replacing the SIM card, you won't be asked for PUK anymore.
Posted on Sep 09, 2009
Heating and hot worker work separately but not together
If this a honeywell valve you may need to change the motor in side the valve , sounds like its lost some of it power to move the inside of the valve to y postion .
Nov 04, 2012 | Honeywell Programmable Thermostat Heater
The hw/ hw+ch rocker switch on my danfoss set 2e heating programmer is not working
Rocker switch stuck on replace programmer or diverter valve stuck in ch postion .
Aug 13, 2012 | Heating & Cooling
ST9400A showing code 621 , heating not working but HW is stuck on
You cab check the hw by turning up the thermostat on the hot water side . On the heating check pump is working and check if diverter valve is working on the ch side .
Feb 01, 2018 | Heating & Cooling
Ariston washing machine. Error code F09
Most Indesit ( Hotpoint, Ariston) machine's 'F09' decodes as ' incompatible eeprom' or eeprom error, check/change eeprom'. Sorry, whichever it is requires an engineer call ;-0(
Hopefully it might only need connectors reseating.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | Ariston Technologies Washing Machines
Cosa significa il codice errore F12-F09 in una lavatrice whirpool modello AWM8103/2
la lavatrice mi si blocca con un codice F09 e poi dopo una diagnostica finisce in FA. Posso fare qualcosa per sbloccarla... si è rotto l'acquastop? Grazie
Jan 11, 2011 | Washing Machines
My central heating pump does not switch off when the acl lifestyle model lp722 central heating timer switches both the hot water and c/h off. pump keeps running through the night
if you can turn off the hw and ch off , to the off postion and it shuts off then the acl lifestyle could needreplacing mine did the same on ch only so changed mine , or check the divtervalve is working and not stuck in the open postion , try turning hw on and off only then the ch see if valve works
Jan 08, 2011 | Heating & Cooling
CARD DISABLE CH:20363 DATA: Null DIAG: UsbCdc HW: B119.00 SW: CJ29 Please help on this, how to resolve.
is sim car disabled. if so then remove sim and jailbreak it and download yellowsnow and unlock it
Oct 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Samsung SGH-d807 Cellular Phone Logo
Top Samsung Cell Phones Experts
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
