16gb pendrive whan i insert the drive it shows the disk needs to be formatted but when the formatting is completed it shows that the windows cannot complete the disk formatting.
plz tell me solution for this problem.
You have to format that pen drive. Through DISKPART . This action delete your all Data from your pendrive.
Attach your pendrive into you computer or laptop.
1. Go to CMD
2. Type DISKPART
3. Type LIST DISK
4. You see that your computer showing 2 Disk.
5. Select your pendrive be sure that you select your pendrive by typing the command.
SELECT DISK 2
6. Now type CLEAN
7. Type CREATE PARTITION PRIMARY.
8. Type FORMAT FS=NTFS QUICK
9. Type ASSIGN .
10. EXIT
Now you can see that you pendrive showing full capacity .
reference: https://www.quora.com/I-have-a-16GB-pen-drive-but-now-it-is-showing-only-4-MB-How-can-I-solve-this
hmm raw file system it seems like it does need formatting however try doing so in disk management (right click start menu and click disk management if in windows 10 if not go to control panel and go to admin tools then double click on computer management inside the program you can find disk management)
may be the flash drive is locked...unlock the pendrive and then try again. formatting can be done in other way. goto run,type cmd,press enter,then type format f: in the cmd and press enter.this formats the drive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
