Battery light comes on to tell me the battery is charging then after about 1 min it flashes fast and I know the battery is good. I took the battery out and the charging like is flashing as if the battery is in place can anyone help thanks.
Sometimes when a battery is too low it takes a while for it to initialize in a charger and begin to charge. Clean the battery contacts with a pencil eraser and put it back on the charger. Leave it on the charger despite the blinking light. Leave it on the charger for several hours and see if the flash stops and it becomes a constant light indicating normal charging. If this does not work, you may have a short in the battery or in the charger itself. Try another known good battery in the charger and see if you have the same problem. If so the charger has an issue.
Best regards.
SOURCE: Battery will charge if off of radio will not charge if attached to radio
look on the battery , you sould see a 3 digit code. EG if you see a code like 458 . this means week 45 ,2008 or if it is 123. this means week 12 at 2003. The motorola batteries last up to 2 yrs. if it older than 2 years old , replaced the battery
SOURCE: won't receive or transmit
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
SOURCE: Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
SOURCE: Red light flashing
It is either defective, or it has something touching one of the contacts causing a short. It would be best to replace the charger. Typically they are somewhat like a light bulb, they will burn out over time and need replaced.
SOURCE: 1. isthe battery charging 2.isthe charger
You don't mention a make or model, so I can only give you general solutions. If the radio has a drop-in charger there may be a light to indicate charging. If the light comes on when the radio is in the charger, it's getting a charge. If you have a multimeter, DVM, or DC voltmeter you can check the battery voltage (charge) both before and after a charging cycle. You can also use the meter to confirm the output from the charger. If possible, replace the batteries with standard alkaline types and see if the radio works. I hope this info helps.
Bill B.
San Antonio
