Setup instructions Where can I get the user manual or setup instructions for a Samsung scx-4725fn? When I try to program in my fax's phone number, it asks for an ID #. I don't have the manual anymore, so don't know what to do. Thanks!
you may try uninstall the driver and reinstall the new driver from samsung website. www.samsung.com
it might help to resolved this issue. make sure that after you install the driver do a test print and set the paper size to a4 as default it is set to letter.
You configure you fax program.Such as line type,fax number,or you follow user manual,how can use it?
It is problem setup or configure not problem machine.
Having encountered this issue, I read the manual. The only way I found it to work was to press scan and then choose the application that you want to use. I normally just choose scan to Paint. Then launch Paint on your pc, Go to File and select From Scanner and Camera and your image will appear in Paint. (not the easiest scan method in the world but it works; I have tried selecting the other applications on the scanner menu but haven't had any success.
