Is this normal? Says in the manual it could happen time to time and not to worry but this is the 3rd time it happened and has been pixelated and snowy for almost an hour.
I can take it back now with no concern - store had a 30 day problem free warranty - but I don't know if this is normal for all larger tvs. I do have a 32" lcd Philips TV that never had an issue.
SOURCE: Sharp aquos lcd screen goes blank
The problem is most likely the the screws are loose on the inverter boards. The screws must be tighted as they provide the ground to the inverter bds. The inverter boards are undet the shields on both sides of the unit after pulling the back cover. One way to make sure that you are losing back lights and not video is when your picture goes black, shine a flash light on the screen at an angle and will see the video is still there. This mean the back lights are out. If you do not see the video it may be another problem
SOURCE: Sharp Aquos 36 in. HDMI LCD
remote ceased functioning! What did I do...and how do I undo it?
SOURCE: Sharp Aquos 32" lcd hdtv, looses video, audio still works.
that's D44 serial common problom,the cables connected to the panel made the problem
SOURCE: odor comming from lc42d77x aquos sharp lcd tv
LCD TV don't give off odours unless there is an electrical problem, like burnt plastic smells. Can you describe the type of odour?
Could be some kind of insect etc. that is traped inside and died.
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
What feed do you have on the TV when this happens? Cable, DVD, video games?
