Question about General Electric WHDSR316G Top Load Washer
No spin or agatae
Washing machine GE WHDSR316G1WW will fill but won't agitate or spin. It will run its cycle fill & empty
Posted by Wally Warmus on
  • 1 more comment
  • ryowell Mar 27, 2009
    Fills with water but won't agitate or spin.
  • conradroach Apr 01, 2009
    I have the same problem with the same model washer.
  • ashudson Apr 05, 2009
    Fills with water but won't agitate or spin, then draind out. I had this happen when the washer was a few months old. We called GE and they said the sensor on the lid needed to be reset. They gave me the steps. You had to unplud it and open the lid several times. It worked. Now it just turned a year old at end of March and having the same problem. Now when I called GE, they says they have pulled those notes off their system and I have to schedule a service call. I will never but a GE washer again.
Anonymous
    New Friend:
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Posted on Nov 03, 2009
  • white_gr8
    white_gr8 May 29, 2012
    Thank You! I tried it and it worked! I had to do the door opening and closing relatively slowly for it to take.
  • Kimberly Castro
    Kimberly Castro Oct 04, 2012
    ty i tried it too and it worked for me!!!!
anantha reddy
    Sergeant:
    Champion:
  • 205 Answers
Hello mam please check the motor of the machine
Posted on Sep 22, 2009
  • anantha reddy
    anantha reddy Sep 23, 2009
    hello mam
    have you checked the motor
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
My washing machine is stuck on agitate. It filled and agitated then stopped. I can set it to spin only and it will spin and empty the tub, but for a regular wash cycle it starts on agitate and stops...
You may have broken teeth on the gears in the timer assembly. Do you have a habit of "whipping" the timer around? In other words, turning the timer fast.
Dec 14, 2009 | GE Washing Machines
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
hi, reset the printer.
open th right door,without paper then close the door
it work
thank you
May 17, 2009 | General Electric WHDSR316G Top Load Washer
My ge hydro wash washer model WHDSR316G1WW will not spin or agitate. It did this same thing a couple of months after I bouht it, the serviceman said the belt was off. I've checked the belt and it seems to...
for model: WHDSR316G1WW General Electric Washing Machine
Unplug the machine at least 30 seconds
Turn the dial to the spin cycle, but do NOT pull it out yet.
Plug the machine back in and then lift and close the lid 11 times within 15 seconds and finally pull the knob to start the washer on spin cycle.
This should clear the error code.
GE service 1-800-626-2000 (option 3)
Apr 23, 2009 | GE Washing Machines
General Electric WHDSR316G Top Load Washer Logo
1,506 people viewed this question
Top General Electric Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
