Pull out on the clips on each side while pushing on the red part in the center of the clips. Pull black bottom away from the red top while pulling out on the clips.
It may just be the fan slowing down and acting like a siren, or it may be a dry bearing. Take it all apart, clean and lubricate. Replace the carbon brushes perhaps whilst you are in there.
Go to http://aerushome.com/ to locate an authorized shop near you.
Their service department will have the info, but generally will require the machine to be brought in to be repaired.
Yes replacing the link would work, but that would not fix the cause. You have either pulled the wiring to the point of pulling apart the connection or there is a short. Which would be in the way of a grounding effect causing the link to heat and melt. A safty issue to be sure. Check all contact with housing and motor to make sure there is not an underlying problem to start with. Unpluged of course
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
I'm afraid you'll need to take it apart. the switch is mounted in a plastic holder in the top.
While you got it apart and without it plugged in, check to see that both brushes are touching the commutator. there should be sufficient spring tension to hold the brushes against the spinning part [commutator] if even one brush isn't making contact it won't spin.
