Question about Black & Decker PI400AB Power Inverter
Replace fuse How can I charge a Black & Decker PI400AB Inverter so it will run again?
Posted by james latten on
1 Related Answer
Anonymous
  • 142 Answers
SOURCE: Replacement Fuse
40 A
Posted on Jun 14, 2010
Hi i have a 400w black and decker inverter as soon as i plug my lap top in to it the power light on the inverter flashs and it wont power my laptop
The output of this inverter (and most others) is a modified sine wave, which isn't quite the same as a true sine wave - like you get from a wall outlet. Unfortunately, most transformers (which is essentially what your laptop power-supply is) require a true sine-wave. Your inverter will work fine for many other 110V applications. You can buy an inverter with a true sine-wave output, but they are more expensive.
Aug 19, 2010 | Black & Decker Power Inverter PI400AB
I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Jul 15, 2010 | Black & Decker Power Inverter PI400AB
400W Black & Decker Power Inverter Doesn't Power My LCD TV
The problem of your inverter is from
your battery .your laptop and dvd
player requires little current to
operate.But you tv requires more power
to run, if your battery is low you it will
not last for 3 minutes. If your battery
has a low current rating, it will also be a
cause, for example, if it is below
100ampere hour. Lastly if your battery
is bad i.e. if it reads below the
stipulated dc voltage Require by your
inverter to operate.
May 09, 2010 | Black & Decker Power Inverter PI400AB
How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
Feb 12, 2010 | Black & Decker Power Inverter PI400AB
Black & Decker P1400AB fuse change
If it is the fuse inside the cigarette lighter plug, just unscrew it and put a new fuse in.
If you mean replacing the two 25amp fuses inside the inverter housing, you can bypass the fuses by soldering the two sides together. Or, if you want to put new fuses in, heat the solder holding the fuses in until they pop out and insert new ones.
As for opening the housing, good luck!! I ended up using steel cutters to rip off the plastic. The best option would be to buy a new one and return the old one in the package.
Jan 16, 2010 | Black & Decker PI400AB Power Inverter
My inverter started flashing its green light now it wont turn on, i have checked the internal fuse's they are good, next i checked the fuse's in my car and they are good, i even tryed plugung in another...
This inverter is a good Walmart inverter.
I had one that worked for about 6 months.
There really is no affordable fix.
RECOMENDATION:
Take it back if you can as soon as you can, dont fix it..
Hope this Tip Helps.
r/
David
Jan 09, 2010 | Black & Decker Power Inverter PI400AB
Why does the power inverter keep beeping when i plug up my laptop
If your not getting enough voltage to the inverter it will beep to let you know you don't have enough power. Most common cause is a lose connection thru your cigarette lighter. Also if you turn your key off it might be shutting down power to your plug.
Make sure you have a good connection with your battery or plug adapter. You also need a good battery so you don't go into a low voltage condition which will make your inverter beep.
Oct 29, 2009 | Black & Decker Power Inverter PI400AB
Black & Decker PI400AB Power Inverter Logo
79 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
