Hi. Goto
www.kitchenaid.com enter your model # into the search window, look for the parts catalog for your mixer. Download this file. It will come in handy if you ever need to order parts, and will give you an overview of your mixer.
Goto
www.mendingshed.com and locate the free Kitchenaid Service manual. This manual contains all of the info needed to service your mixer.
Finally, your mixer uses grease for lubrication. When you see oil dripping, it means that your mixer needs to be re-greased as the oil is separating from the grease base. I recommend Chevron FM ALC EP-2, this is a food grade grease that is non-toxic should you get some of it's oil in the mixing bowl at a later date. Remove the old oil and grease remnants from the mixer, including the planetary unit. You can remove the planetary by tapping the tapered pin out of the shaft. Clean and re-grease. After you've completed these tasks, run the mixer for a couple of minutes every week to keep the oil in suspension. This will extend the life of the grease.
Good luck! If this solution has assisted you, please rate it. ricardok45.
