Univex M60 Stand Mixer Logo
Posted on Mar 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do i get the maintance manual to grease up keep my mixer
What parts need to be lubed and maintained. and what do i need to do this myself. where do i get a maintance book?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 234 Answers
  • Posted on Mar 19, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
234
Questions
0
Helped
162938
Points
513
1 Related Answer
Anonymous
  • 20 Answers
  • Posted on Jul 07, 2009
SOURCE: where do i get the maintance manual to grease up keep my mixer
Here is a parts list and operators manua
There lube is very heavy and it cost about 20.00 a tube
http://www.univexcorp.com/pdf/SRM20F20PLANETARYMP.PDF
Ed
Service advise for kenwood a700d
The planetary gear housing is filled with grease. Seeing oil come out would indicate that grease has started to or has completely broken down. Take the planetary apart (One nut and a clip), clean out the old grease and liberally repack with a food grade grease something like PTFE Super Lube .
I have a KSM90 that is about 8 years old. It started leaking oil and the top of the mixer goes down into the bowl too far and it 'drags' the attachment along the bottom of the bowl and makes a generally...
It sounds like the Planetary Gear assy. has gear lubricant leaking into it from the gear case above it. This may not be that unusual so there may be 2 possibilities or a combination of both. The Gear Case is directly above the Planetary Gear assy. It is filled (sort of) with a food grade (assuming...I hope) grease that is necessary to keep things lubed. There are fiber washers and possibly an o-ring in the shaft assembly which should keep the grease from migrating toward your food. The Planetary Gear assy. is the part that rotates around on the business end of the mixer. It has a bronze bearing that is intended to run without lubrication. However it is a wear point and if worn sufficiently, could allow escape lubricant from the gear case above to drip into your mix. The Kitchen Aid Service Manual is a good source of info. You can get it as well as complete diagrams of the internal parts at:
http://www.goodmans.net/get_item_ka-4162075_kitchenaid-mixer-4162075-planetary.htm
You can also get parts and the KitchenAid Service Manual.pdf at:
http://www.mendingshed.com/kitaidparts.html
I know if it was my mixer, I'd give it a look. They're good tools and worth the effort!
Good luck.
DZII
1helpful
My kitchenaid mixer was stored on its side and leaked oil. I don't dare use it now. Can I replace the oil myself? There are no mixer repair centers anywhere near me.
your oil leaking is cause by a bad gasket or the gasket isn't seated properly. you can purchase this gasket but replacing it does require knowledge of the unit. part number for the gasket is 4162324. the grease can be purchased locally at any car parts dealer. generally a thicker paste type grease is used inside these units, but the original part number for the grease is 4160588 and comes in a container with enough grease for 5-8 mixers.hope this helps
Thanks
9helpful
Leaking oil where beaters connect
Hi Maureen. Your K45SS needs to be serviced. The old grease and the oil that has separated from the grease must be removed and the unit cleaned. If you, or someone you know, are up to the task, go to mendingshed.com and download the Kitchenaid Service Manual. This very thorough manual will assist you with the task at hand and with future repairs.
The replacement grease I recommend is Chevron FM ALC EP-2. This is a "Food Grade" grease which is non-toxic should some drip into your mixer bowl at a later date. The planetary gearing should also be removed, cleaned and regreased.
Go to kitchenaid.com, click on Customer Care and click on the Manuals button. In the search window, enter your model number thusly, k45sswh and download the parts drawings for your mixer. These drawings will give you an "exploded view" of your mixer and will come in handy if you need to order parts. Mending Shed also sells replacement parts.
Once your mixer is back in service, run the unit for a couple of minutes every week, this will help keep the oil suspended in the grease and extend the life of the grease.
If this solution has assisted you, please rate it. Good luck! ricardok45
4helpful
Adding oil to the k45ss
Hi. Goto www.kitchenaid.com enter your model # into the search window, look for the parts catalog for your mixer. Download this file. It will come in handy if you ever need to order parts, and will give you an overview of your mixer.
Goto www.mendingshed.com and locate the free Kitchenaid Service manual. This manual contains all of the info needed to service your mixer.
Finally, your mixer uses grease for lubrication. When you see oil dripping, it means that your mixer needs to be re-greased as the oil is separating from the grease base. I recommend Chevron FM ALC EP-2, this is a food grade grease that is non-toxic should you get some of it's oil in the mixing bowl at a later date. Remove the old oil and grease remnants from the mixer, including the planetary unit. You can remove the planetary by tapping the tapered pin out of the shaft. Clean and re-grease. After you've completed these tasks, run the mixer for a couple of minutes every week to keep the oil in suspension. This will extend the life of the grease.
Good luck! If this solution has assisted you, please rate it. ricardok45.
5helpful
Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
2answers
Need to buy a switch for the c-100 hobart mixer?
Hi. Hobart no longer makes or sells parts for the C-100 model. It's considered obsolete.
Your best bet is to locate a used restaurant equipment supply place and ask around. Sometimes these places keep old mixers for parts. Another option is to do a search on eBay, as there are several sellers that deal in obsolete parts. Failing that, a local electrician may be able to fabricate a new one or adapt some some other type of switch.
With a unit as old as this, it's important to maintain a good re-greasing schedule (once every five years), and your mixer will keep on delivering the goods for years to come.
If you found this solution usefull, please rate it as fixya. Good Luck! ricardok45
2answers
Type of lubricant for bowl lift
Go to an auto parts place and buy some Lubriplate grease and use this on the assembly.
1helpful
4answers
Hobart A 200 Mixer - Lube
HI Joe
I have the wrong greace in my A200 standmixer i need to know what kind and how much to put in gear cace. thank you
Top Univex Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you an Univex Food Mixer Expert? Answer questions, earn points and help others
