Dell Xps 15 Laptop Computer (Intel Core i7 740QM 640GB8GB) (dndogx41) PC Notebook Logo
Question about Dell Xps 15 Laptop Computer (Intel Core i7 740QM 640GB8GB) (dndogx41) PC Notebook
Continuous beep/crackled audio
My Dell XPS 15 L502x has been emitting a loud and continuous beep noise since last Friday. The sound is also horribly crackled and distorted.
joecoolvette
  • Dell Master
  • 5,660 Answers
Beep noise you hear is a BIOS Beep Code
The computer's way of letting you know something is wrong, and an area to look into for it.
Loud and continuous beep, usually indicates a problem with the Processor (CPU).
To be more specific the Processor is overheating.
More specific than that, it is caused by the laptop is dirty inside.
Air is used to cool the hardware components inside the laptop, with the cooling system.
The two hardware components that give off the most heat, is the CPU (Processor), and graphics chipset. (GPU)
The cooling system consists of;
1) Fan Assembly
2) Cooling Tube
3) Heatsink
http://www.parts-people.com/index.php?action=item&id=11931
Click on the image to enlarge.
The aluminum die-cast metal plate you see to the far right, sits on the Processor. (CPU)
The small metal plate is connected to a Cooling Tube.
The small aluminum metal plate to it's left, sits on the graphics chipset. (GPU)
As you can see it also is connected to a Cooling Tube.
Both Cooling Tubes end in a black rectangular finned, Heatsink.
What is not seen of the cooling system, is the Fan Assembly,
http://www.parts-people.com/index.php?action=item&id=10804
The flat part of the D-shaped shroud, of the Fan Assembly; rests up against the finned rectangular Heatsink.
A) The Cooling Tubes are a slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
B) The Cooling Tubes end in a finned Heatsink. A thin small strip of metal, that has tall thin fins protruding from it.
C) The Fan Assembly consists of a small multi-bladed fan, encased in a D-shaped shroud.
The fan draws air up from the Center, (Bottom of laptop), and exhausts the air through the fins of the Heatsink. (Then out the side of the laptop)
Heat from the Processor, and graphics chipset, is absorbed by their small respective metal plates, that sit on them.
The Cooling Tubes then absorb the heat from the small metal plates.
The Cooling Tubes transfer the heat up to the finned Heatsink.
The Heatsink absorbs the heat, then radiates the heat away with it's tall, thin fins.
Air flow from the Fan Assembly, helps carry heat away from the fins of the Heatsink.
When the fan blades, center hub, and surrounding cage, (Shroud), get dirty; the cooling capacity drops tremendously.
Just a light coat is all it takes.
When the fins of the Heatsink are clogged with 'Gunk', the cooling capacity drops tremendously.
Gunk = Dirt, dust, lint, hair, food crumbs,.......you name it.
Also in-between the small metal plate on the Cooling Tube, and the Processor; is Thermal Paste.
The top of the Processor, and the bottom of that small metal plate on the Cooling Tube; are not perfectly smooth.
A magnified view would detail, 'Ridges, Valleys, and Pitholes'.
When the two parts are mated together, there are air pockets formed.
Thermal Paste fills these imperfections, and is an Excellent conductor of heat.
In-between the graphics chipset (GPU), and it's respective small metal plate, a small piece of Thermal Pad is used.
A Thermal Pad is a material that is impregnated with Thermal Paste.
After time (Age), and also due to overheating; the Thermal Paste can dry up.
Looses it's thermal conductivity properties.
Same goes for a Thermal Pad, as it's Thermal Paste dries up.
After cleaning it is suggested to replace the Thermal Paste PROPERLY, and replace the Thermal Pad.
A Thermal Pad CANNOT be reused.
Do NOT care if it looks like new.
Once the impression is made into it, from the small metal plate, it's DONE. Small metal plate will not contact, the Thermal Pad's surface correctly again. REPLACE.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.hardwaresecrets.com/article/274
http://www.newegg.com/Product/Product.aspx?Item=N82E16835230030
Suggest use a can of compressed air for computers, Tweezers, and a small soft brush. (Makeup brush?)
This is an example of what a dirty laptop looks like inside.
Using the Dell XPS M1710 for an example,
http://www.youtube.com/watch?v=AkAeE5I5E_A
This is Dell Support > XPS 15 (L502X) Notebook PC > Main Support page,
http://www.dell.com/support/troubleshooting/us/en/19/Product/xps-l502x
Click on the Manuals & Documentation tab.
(Product Support / System Configuration / Drivers & Downloads / Parts & Upgrades / Manuals & Documentation / etc )
Click on the blue - Service Manual (1451KB)
The Zoom In icon ( + ) at the top, increases the view size; when you click on it..
The Zoom Out icon ( - ) decreases the view size.
Click on - Heatsink - in the right column.
HMMM, never mind!
Seems this particular PDF file is messed up. Or it's on my end. You may have better luck.
Instead scroll the page down until you come to - System Board,
OR;
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
1) Put your mouse cursor in the page number box, left-click once.
(Everything in page number box is now highlighted in blue)
Left-click.
Now Backspace any numbers out.
2) Type the page number you want.
3) Press the Enter key.
Go to Page 45
Additionally,
http://www.insidemylaptop.com/how-to-disassemble-dell-xps-15-l502x-laptop/
When you get to Step 27, you can access the cooling system, to remove it. (Replace Thermal Paste/Thermal Pad)
Regards,
joecoolvette
Posted on May 21, 2013
5 Related Answers
Thomas F. Schneider
  • 2715 Answers
SOURCE: Dell Latitude D620 showing ' no audio device'
You  need both a sound device and a sound driver. Reinstall the sound driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D620&os=WW1&osl=en&catid=&impid=
Posted on Mar 02, 2009
Anonymous
SOURCE: Dell D620, freeze with continuing lound sound Beep
Try running a good registry cleaner like Glary Utilities or Advanced Widowsystems. That should help. Also try checking for driver updates on Dell site.
Posted on May 21, 2009
Anonymous
  • 240 Answers
SOURCE: speakers on new dell Studio Laptop 1737 crackle and pop
Likely, what you are experiencing is the fact that the batteries in your speaker are running low. The sound of this speaker – as with any battery operated device – is reliant on fully-charged batteries. When the charge gets too low, you will experience sound distortion or abnormalities. Just put in fresh batteries, and you should be all set.
Posted on Jun 18, 2009
Anonymous
  • 3940 Answers
SOURCE: My Dell XPS M1330's internal speakers are not
#1 Flash the BIOS to the most current version. #2 Run diagnostics from the F12 menu (Or Power plus FN key) see if the speakers work in the diagnostic. If they work in diags, there is no hardware issue, only a software issue. If you get no sound in diags, try a pair of headphones, if you still get no sound, then it is a hardware problem. If you only get sound in the headphones, then the microswitch that disables the speakers is stuck. #3 is sound works in diags then you have a problem with the audio driver or speaker configuration (Audio muted etc)
Posted on Jan 07, 2010
Michael Kennedy
  • 233 Answers
SOURCE: Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Posted on Nov 02, 2012
What is dell xps error code 2008-0333?
No sure never seen 2008 ..2000-0333 on a desktop is suggestive of video card. If you got this by running ePSA, there should also be a validation code. Any beeps or post lights when pc is first starting.?
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Replace fan dell l502x
If you haven't attempted something like this before, I would suggest that you take it to a shop. If you want to have a go anyway, look on youtube for the same question.
Dell Laptop not powering up - emitting 3 beeps
see p.47 of your manual
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-15-intel-n5010_setup%20guide_en-us.pdf
This says 3 beeps means "Possible system board failure - Chipset error" which sounds serious. Are you certain it is three beeps ? The manual recommends contacting Dell (see contacting Dell on p76). Inspect each chip on the m/b for damage (you may not find anything). You might try disassembly and reassembly of the computer (see Service Manual on Dell website) if you are competent to do this, and cleaning it out with a can of compressed air.
14.April.2014
5helpful
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
2helpful
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
1helpful
1helpful
Multimedia audio controller exclamation sign
try this driver
http://www.drivershq.com/Drivers/VistaDevices/DELL-Audio-Realtek-ALC850-AC97-AUDIO-Driver/4342/Drivers.aspx
or
http://drivers.softpedia.com/progDownload/Dell-XPS-600-Audio-Driver-Download-40848.html
or try all these dell audio drivers from here
http://www.drivershq.com/VistaDrivers.aspx
or buy a vista compatible sound card
Mehandi Husain ...
Steve Sweetleaf
Steve Sweetleaf
