Question about Altec Lansing MX5021 Computer Speakers
Altec lansing mx5021 parts
Amplifier card
Anonymous
  • 38 Answers
SOURCE: MX5021- Remote pod station w/volume, bass and treble control
yes
Posted on Dec 04, 2007
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
Tip
Car amplifier troubleshooting
No output:
  • Confirm that all terminal strip connections are firmly connected.
  • Check in-line and built-in fuses. Both +12V and RMT terminals must have +12V to chassis ground.
  • Confirm that signal source ( Car Radio/Deck, EQ, X-over etc) is connected and is supplying output signal.
To confirm that Amplifier is working, connect an RCA patch card to LEFT& RIGHT low-level inputs of Amplifier only ( Do not connect the other end of the patch card).Briefly tap the center pin of each ( disconnected) RCA plug on the other (disconnected) end with your finger. This should produce a noise (feedback) in the speakers.
If this tip in anyway helped you please do not forget to rate it, thanks.
on Feb 19, 2010 | Car Audio & Video
Hi,how do I connect up two 5.1 surround sytems to my PC Pavilion m9451ch I know all I need is a 3.5mm RCA jack into the amplifier and connect them up with the outlets on my computer this is OK for one but...
First, you need a sound-card in your computer that is capable of '5.1' operation.
Second, you need a receiver/amplifier that accepts '5.1' input.
This is usually achieved by a "optical digital" output on the computer's sound-card,
an "optical digital' connection cable, and an "optical digital" input on the amplifier.
May 09, 2011 | HP Computers & Internet
How do i connect the souncard to an amplifier for speakers
To conect a sound card to an amplifier is easy onect the pin to the audio out put of the sound cand and to the audio in in the amplifier and make the selection mode as aux then the sound card will be amplified with amplifier also increse the volume in the sound card to approximate level
Apr 05, 2011 | Numark DJ/iO Sound Card
Bluesky bcr716
baga alt sd card cred ca nu citeste sd-hc card
Jul 27, 2009 | Jensen 100W x 4 Amplifier KA5 Car Audio...
The volume is too low on my computer speakers
Hi, Mark Here, see I can help.
The 1907 does not amplify your sound it will let you control the volume to some degree but not boost the incoming sound.
If you had amplified speakers b4 your sound card requires amplified speakers.
Best two options i can give is.
  1. If it is a desktop you can install a amplified sound card. Hook to monitor speaker.
  2. Unplug monitor speaker &use amplified speakers.
Just so you know laptops use internal amplified speakers. If you decide to install sound card make sure it is an amplified card.
Hope that fixed ya! know not the best news. Need more help comment back. Please Rate.
Good Luck!
Mar 28, 2009 | HP w1907 LCD Monitor
Which operational amplifier is good for output of sound card ?
I use an 80 watt yamaha with sub woofer but there is several good ones out there.There is Logitech, Philips, Bose and J.B.L. that's just a few but these are about the best ones.
In Christ Greg
Nov 17, 2008 | Aardvark Direct Pro LX6 Sound Card
Dell PC with ATI Radion X1300 Pro using High quality short DVI cables
Hey there Carol H, I would agree that the amplifier is the likely source of the distortion or picture break up. It is the last in the series of steps therefore most likely the problem. Also the problem did not appear until the signal ran through the amplifier, thus indicating that the amp created rather amplify the problem. If your need is to have multiple monitors installed on one machine, I suggest you consider a system which supports Scalable D.G.E., Crossfire, or SLi technology. These allow multiple video cards and therefore multiple connections, as well as improving overall performance, and reducing strain on system resources. I hope this helps. Good Luck!
Nov 22, 2007 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Dec 28, 2006 | Kicker (ZX750.1) Car Audio Amplifier
Altec Lansing MX5021 Computer Speakers Logo
89 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
