Samsung HP-R5072 50 in. Plasma HDTV Logo
Posted on Mar 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung hdtv switches off when i connect my laptop
Acer laptop
samsung tv
avg coonection
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Mar 19, 2009
Anonymous
Expert
Level 2:
Answers
53
Questions
Helped
20371
Points
157
Check your laptop display resolution before hooking up the avg. the max res. is 1366x 768. at higher resolution the tv will just turn itself off..
please rate my comments :D
3answers
How do i connect aspire 5810t vista home pre 64b laptop to samsung lcd hdtv via hdmi
As long as you have an HDMI port on each hardware, just insert the HDMI cable into the ports and it should work fine.
Hope this helps
I cant connect my acer aspire 5810 tg with my samsung lcd tv.the tv say "NO SIGNAL"
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Connection to television
Well if you TV is compatible with HDMI then that is all you will need, HDMI supports extremely good video and audio quality. But you need to make sure your TV settings are correct and any software needed for your TV to sync to your laptop are being used. Ex. my samsung LCD HDTV requires that I use their sync master program with my desktop to run it on my TV under the DVI source channel.
check out my site!! http://ctrlr4repair.webs.com
1helpful
Samsung x05 wireless internet net working
try reseting ur router then connecting
2answers
HDTV won't diplay/detect input from my Acer Laptop
A u sure u have extended windows desktop or put it in to clone mode. maybe u haven't selected proper source on TV. just try with something besides TV maybe cable is too long or not working.
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
hi if you laptop has the s-video you can connect that to the tv an it would work
54helpful
10answers
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
  1. Make sure your TV and computer are off.
  2. Using a 15 pin D-sub (standard) video cable, connect the Video Out jack on your computer's video card to the PC In jack on the back of your TV.
  3. Using an audio cable with a min-stereo plug on one end and two RCA jacks on the other, connect the Audio Out jack on your computer to the left and right PC Audio In jacks on your TV. (Note: If you have your computer connected to separate speakers, you can skip this step)
  4. Switch on the Notebook and Adjust the Resolution (800 x 600 pixels would do). You can go to Control Panel and Adjust the screen resolution. (Keep ‘Screen Refresh rate’ at 60hz in the Monitor Settings)
  5. Switch on the TV and try to Select the Source as 'PC' (you can do this by either pressing the 'Source' button several times on your TV remote or go to the Menu - Setup and Select the 'PC' as source there).
  6. In most cases, after following the above steps, the TV would start to show 'Auto Adjusting' message and it will start showing your Desk top on the TV. But incase it doesn't work, you can do the following:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
2answers
Laptop to TV
Do you have dual display activate on Laptop?
Problem
in travelmate of acer,the wireless connection is built-in what your going to is to configure it.Go to the wireless connection icon it is located in the right-down of your laptop.right click,then click the status,then click connect.your notebook will automatically find the nearest connection of internet
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
