Question about GE Spacemaker JVM1640SJ Microwave Oven
Door latch hook broke on bottom, when closing microwave door microwave comes on so door has to be left open or microwave unplugged, does not seem to heat however...will replacing the door latch hook fix this, and how hard is this to do...this is for the ge spacemaker over range jvm1631wj01 microwave oven.
  • Anonymous Apr 01, 2014
    door hard to open
    door hard to open
    Sergeant:
    Champion:
  • 234 Answers
You can find the parts at a GE appl.dealer.
Posted on Mar 19, 2009
6ya staff
SOURCE:
Door won't close
Check latch assembly and look for broken spring.
Nov 04, 2017 | Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Microwave oven door wont close
Most microwaves will have a spring loaded latch on the door. The likely issue is the clip for the spring has broken. Unplug it, put it on the benchtop and pry open the inside of the door. It's usually a soft plastic cover that with a gentle persuasion from a flat screwdriver will come off. Start above the latch and pry open as much ad needed. Locate the spring at the bottom, open up one of the fixing loops on the ends with long nose pliers and attach it to a fixed spot around the inside of the door. There are usually metal ribs inside the door and attach the other loop to the base of the latch
Mar 09, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Sep 14, 2008 | Sharp R-1870 Convection/Microwave Oven
Panasonic - convection/microwave oven door is stuck shut spring will not open same -dinner in oven help
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can order Panasonic parts here.
I hope this picture shows up - it helps illustrate:
Aug 10, 2008 | Panasonic Microwave Ovens
Panasonic inverter door won't shut, light stays on.
Thanks for the tips - here is what I did (my wife calls me the Canadian McGuyver!) After taking off the plastic frame (using instructions in Solutions noted above) I used the metal part of a key ring and hooked one end to the spring and looped it around the thick finger/protrusion at the bottom. _197.jpg
Jan 28, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
554 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
