Saitek Aviator AV8R Joystick Logo
Question about Saitek Aviator AV8R Joystick
Saitek AV8R-01 Joystick - How to install?
Do I need a down load disc to install the Saitek AV8R Joystick (AV8R-01)? If so, what else if anything do I need to know about this product? For example what type of games would I be able to play? Do I need to buy the games from stores or can I find games for this product online?
Also can some instuctions be sent to me in my e-mail about the joy stick itself? For example, What does each different button do?
Posted by lady_faith_1 on
  • Anonymous Apr 18, 2009
    i have the same problem SOMEBODY PLEASE HELP US!!!!!
Anonymous
No download disk is required. Your PC will automatically 'find' the joystick after it has been plugged into a USB port.
You can just about play any flight sim with this joystick, jat, prop plane or helicopter. The buttons do what ever you program them to do through your game's control settings.
Posted on May 19, 2009
Anonymous
    New Friend:
Do i need driver for sn-ps41 if i work under windows xp
Posted on Dec 26, 2009
1helpful
I have changed my operating system from XP home to Windows Home Premium. my Saitek AV8R-01 seems to be designed for XP. Can I intall a driver that will work with Windows 7
The driver for Windows 7 can be downloaded from here:
http://saitek.com/uk/down/drivers.php
From the second drop-down menu to the right select Joysticks then select AV8R and then select your operating system.
You'll have 2 buttons with the driver and software. Click on each and save the driver to your computer then install them(driver first).
Hope it helps. AV8R AAV8R
I have new Saitek Aviator AV8R-01 Joystick. I want to use it on my MAC Book Pro Computer. I do not see a file for MAC on the provided CD. Will it still work ?
Unfortunately for the moment Saitek does not have any drivers for Mac.
They say they are under development and they are expecting them somewhere this year...
Even so, the most basic functions should work by plug and play since this joystick is a DirectX device.
Hope it helps...
Hi;How do restore the calibration screen for the Saitek AV8R-01. I have a Microsoft Windows XP.
You can use Clear Calibration Utility, which will help you get rid of all the calibration data.
32bit version: http://www.wingmanteam.com/files/Tools/ClrCalib/x86/ClrCalib.exe
64bit version: http://www.wingmanteam.com/files/Tools/ClrCalib/x64/ClrCalib64.exe
Readme: http://www.wingmanteam.com/files/Tools/ClrCalib/Readme.txt
3helpful
AV8R manual
Got to www.saitek.com and download the relevant manual
Joystick turned off, won`t operate
Ok... that is a VERY Easy fix... all you do is get into a plane with the kneeboard and click controls and find it!
2helpful
Windows 98 drivers for Saitek AV8R joystick
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
3helpful
Use of AV8R-01 with Google Maps flight simulator
My blackwidow joystick would not work in google earth, the sim would just crash. I tried a surgestion to remove the blackwidow software and just run it with the ms hid driver. It now works fine, even the throtle and rudder controls.
4helpful
4answers
Saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Top Saitek Video Game Consoles & Games Experts
Marvin
Marvin
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
