Onkyo TA-RW244 Single Cassette Deck Logo
Question about Onkyo TA-RW244 Single Cassette Deck
Gunk fused to record & playback heads of Onkyo cassette deck
I have an Onkyo TA-2600 3-head cassette deck, recently bought used. There seems to be gunk or corrosion on the record & playback heads--as though perhaps a cassette tape was left in the deck for a long time, and the tape itself began to disintegrate onto the heads. I swabbed the heads with alcohol, but much of the stuff remains. Replacing the heads on a 20-year-old machine could get expensive. Any suggestions? Thanks!
Posted by alpine60066 on
  • alpine60066 Mar 23, 2009
    Thanks Grubhead!
Grubhead
  • Onkyo Master
  • 5,750 Answers
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Posted on Mar 23, 2009
1helpful
2answers
Can I run the tape heads on my ONKYO TA-RW411 without a cassette so I can clean the rollers?
When you insert a cassette, there is a finger at the top edge of the player that detects a tape is in the unit. You will need to hold that finger up while pressing play or the machine will not go into play mode.
1helpful
Need help hooking up a vsx-8400 reciever to onkyo eq-240 And a onkyo ta-rw303 cassette deck .thanks
Hello, please contact Onkyo/Pioneer product at 800-229-1687 option #3. Thank you, Onkyo USA
1helpful
ONKYO TA RW11
This would indicate a belt problem as far as the Capstan system goes.
This would need to be worked on by a person who can do a belt change and oil the appropriate bearings.
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Won't record and play sounds muffled
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
My cassette deck Onkyo model Ta 2060 is working slowly
HELLO
By the fault you describe this sounds very much like a belt problem. Take the case off the deck and check the belt(s). Some decks can use more than one belt and you need to look at their condition.
Are they too slack around pulleys maybe? Belts don't last forever and I'm not too sure of the age of your deck. But personally, I would change them all.
Make sure the tape path is clean as well, clean heads, pinch roller and capstan.
2answers
I need replacement drive belts for an Onkyo
i bought some today from **** smith electronic store , i paid $7.97 for a pack of ten assorted sizes
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Onkyo TA-207 3-head cassette deck
The gearing and rubber parts involved in FF or REW vs. play are different. This unit should be overhauled and all of the rubber parts replaced.
Dan
2answers
Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
