I have unscrewed the copper water supply line to the rear of the fridge, but it seems as though the water gets stopped at the little blue cylinder shaped thing that the copper line screws into. Please help.
If you are not getting any water to the ice maker, I would assume that the little blue thing is in fact the water solenoid. These are replaceable at most appliance parts houses.
As odd as this sounds, my Maytag MFX2570AEM stopped making ice. I could feel ice in the tray but it suddenly stopped ejecting or making more even when the bar was in the correct position.
I read many articles telling me the motor was dead, the gears for removing the ice from the tray needed to be replaced, etc. THEN, I read one person who responded that his issue was resolved with a HAIR DRYER. It turns out something about the unit had frozen due to water getting on it, etc.
Sure enough, after blowing a hair dryer into the ice maker for 5-7 minutes I replaced the ice maker drawer and in about a minute it ejected the ice and filled the trays with water again. It has been making ice ever since.
The ice maker's water supply line may be frozen solid. Do not worry... take out your frozen groceries and dairy products, and let your friends store them for two days while your completely defrost your refrigerator. If you don't want to wait, try to locate a schematic (parts diagram) for your fridge and take a panel access cover off to get access to the copper tube of the water supply line inside. (Warning: this can be terminal to your fridge so don't attempt this without the exact parts diagram for your make and model.) Ensure you are heating the water pipe and NOT the refrigerant line; i.e., freon, ammonia, etc... Unplug your fridge and heat up the (water supply) copper pipe with a high wattage blow dryer... if you were a pro, I would recommend a heat gun. DO NOT USE A HAND TORCH as the soldered joint connections may come loose and it will leak afterwards. (The demand you placed on the ice maker caused the compressor to run almost continually for the ice maker assembly causing the copper pipe water supply pipe to freeze... it will take time to thaw it out by just unplugging it. In the future, when you know you need volumes of ice... make a little at a time each day and store it inside a separate ice cube container.) You may also want to check the activation lever above the ice cube container (bin) to make sure it moves freely against the switch contact. If the switch contact is jammed, it won't work. Good Luck
Your inlet tube that goes to the icemaker may be frozen.To Check: Shut off water supply to Fridge, disconnect thewater line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection.I used a zip tie. If the flexible item won't all the throughto the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connecteverything, you now have ice . . . Solution #2: You may have to replace your "Water InletValve" located at bottom right rear of Fridge.Easy to do, just follow the color codes, be sure and shut off the water.
Check the water line that goes from the house plumbing all the way to the inlet on the 'fridge. Are there any kinks? Dirt obstructing the line? You MUST BE VERY CAREFUL when pulling the 'fridge out to check. If you have a copper line, it takes NOTHING for one to kink. And as soon as it kinks...it's done.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
The coil of tubing is normal so you can move the fridge out from the wall without damaging anything.
Your water line could be frozen in
the door. You can disconnect the line at the bottom before it goes into the
door at the bottom hinge. Push the dispenser button and see if it comes out
there. If it does, leave the
door open till it thaws. If it doesn't come out there disconnect
it at the water inlet valve and see if it comes out there. The valve could
be bad. A strainer before the inlet valve
can also get stopped up restricting flow.
Sometimes the valve on the water line becomes plugged and can no longer supply water to the refrigerator. The other options are that the ice maker could possibly not be supplying voltage to the solenoid valve on the rear of the fridge, or the solenoid valve could be bad itself.
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
YOUR WATER VALVE MIGHT BE FAULTY AS THE WATER TO THE FRIDGE IS OK BUT THE VALVE IS NOT OPENING TO ALLOW THE WATER INTO THE ICE MAKER HAVE THAT CHECKED.GOODLUCK.MOHAMED
