Question about Maytag Dependable Care LAT9206
Maytag washer wont fill, spin, or do anything.
I turned my washer on to fill it and it stopped and won't do anything for me. I plugged a vaccum into the outlet and it works, but the washer won't do anything. Is there a fuse I can check or something in the panel that would cause this?
  • Maytag Master
  • 3,361 Answers
Open the control panel and check the micro switch beside the lid switch .
Posted on Mar 19, 2009
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Our washer filled up with water and stopped working. Won't spin or drain, what do we check?
Check for a blockage either in the filter or the outlet hose or the water pump
May 12, 2012 | Maytag Washing Machines
I was going to wash a load of towels and the washer filled up but I realized it wasn't enough water in it so before I could set the dial for more water, it stopped filling up so I set the dial for more...
Look around at outlets that are close by and make sure you didn't trip one of your GFCI breakers or plug in something to the same outlet and make sure you have power at the outlet where the washer is plugged into.
May 30, 2017 | Maytag Legacy Series Top Load Washer
It wont cycle thru anything
There could be several reasons for washer not to fill .Fill washer with water and wait for the timer to get to the drain mode.Unplug the washer from the electric outlet.Open the case, and disconnect the water hose from the outlet of the water pump.If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.Reassemble hose from step 3.Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Thanks for contacting Fixya.com
Nov 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water fills washer even when it is unplugged
Replace fill valve. It is located where the water hooks up to washer. Easy to change. The valve gets plugged with sediment and needs to be replaced.
Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is dead.
Check your washer plug carefully & the fuse in the plug..............may sound silly.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
263 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
