Question about Master Lock TSA Set your Combination Lock With Instant Alert 4687DNKL Pack of 4
Tsa002 won't lock
My tsa 002 will not lock I had changed the combo to 101 but it just won't work. What do i do ?
Posted by Sean on
How can I open a Mia toro carryon with a combination lock?
Is this the TSA 3 digit combo lock on the suitcase? I found a couple of Youtube videos that show how to determine what the code is for your lock. Some of them have a reset button but this technique I think works just as well. Give her a gander.
https://www.youtube.com/watch?v=MBhtFO8fSh8
Hope this helps, if its not the TSA lock let me know. I will find a good hack for you. If this did work let me know that too. Thank you.
Oct 03, 2017 | Locks & Locksmithing
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
Lock tsa 002
What about it??
Apr 26, 2013 | Cars & Trucks
I have a black dog TSA lock and can't remember the combination help
if you have forgotten the combo the only way to figure it out is to progress the combo starting from 000 and then 001,002,003,004 etc...( trying the lock at every new series until you get the correct combo. a 3 digit combo should only take about 10 to 20 minutes to solve. you can cut the time in half if you can remember the first number or the last number.
chris...
Sep 13, 2012 | Ultra Hardware Black Dog 55164 3 Digit...
How can I unlock a tsa 003 combination luggage lock? It has 3 numbers.
I have an REI 3 combo TSA lock that was attached to a backpack. I picked it up from Goodwill so they didn't really have the combination to the lock. After searching for some info online, I ended up just trying to pick it with a paper clip. It was really quite easy to do.
Jul 06, 2011 | Garden
Delsey TSA 002 HOW DOES IT WORK
I bought a TSA.There is no any key.What should I do?I left the country,where I bought.
May 10, 2011 | Locks & Locksmithing
Master Lock TSA Set your Combination Lock With Instant Alert 4687DNKL Pack of 4 Logo
1,210 people viewed this question
Top Master Lock Home Security Experts
ray gallant
john h
Andrew Taylor
Andrew Taylor
Are you a Master Lock Home Security Expert? Answer questions, earn points and help others
