Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Convert calculator what is my height in cm, i'm 5ft 9
Posted by RIchard john borne on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
One inch is exactly 2.54 cm, so if you're 5 ft 9 in then you're about 175 cm.
Posted on May 20, 2013
Please convert 19.5 cm long by 13 cm wide by. 3.5 cm high
I assume you are trying to find to volume (of a container).
Volume of a rectangular prism is length x width x height.
In this case, 19.5 x 13 x 3.5 or 887.25 cm^3.
Good luck.
Paul
What is volume in litres of a bag 230mm dia x 450mm long?
You give only two values for the dimensions, so it must be a cylinder with a radius r=230/2 mm= 115 mm= 11.5 cm
and a height of h= 450 mm =45 cm
The volume for your right circular cylinder is V=PI*(r^2)*h=PI*(11.5^2)*45 cm^3=?
Divide the result by 1000 to convert the volume to liters (1 L =1000 mL=1000 cm^3)
Regular pentagon QRSTU has a side length of 12 cm and an area of about 248 square cm. Regular pentagon VWXYZ has a perimeter of 140 cm. Find the area of VWXYZ. Round to the nearest tenth.
Find the scaling ratio
Perimeter of first pentagon is 12*5=60 cm
Scale factor (2nd/first)=140/60 =7/3
Ratio of areas varies as the square of the scale factor for the lengths
Area of second / area of first =(7/3)^2 =49/9
Area of second pentagon =248 *(49/9) cm^2
Finish the calculation.
Volume of triangular pyramid
Here is to get you started. To increase the size of the image do a CTRL Plus (+) in your browser.
You need to calculate the slant height of the pyramid for the formula of the lateral area. You should find a value of (1/2)*SQRT(203) or about 7.1239 cm
You need to calculate the altitude (height) of the pyramid from the apex (summit) to the center of the base triangle (center of inscribed circle, barycenter, orthocenter). The hypotenuse of such triangle is the slant height. One leg is the altitude (to be found), the measure of the second leg is (1/3) the altitude of the equilateral triangle that forms the base. You should find (1/3) m MH= (1/3)* (11/2)*SQRT(3)
1. Calculate the area of the base (use a formula for the equilateral triangle or the general formula for a triangle: you have its height MH ).
2. Lateral area = 3 times the area of triangle Triangle ECD (in yellow above).
3. Total area = area of base + lateral area.
4. Volume= (1/3)(Area of base)* (height of pyramid)
If you can see the details on the screen capture below, fine, Press CTRL + in your browser to increase the size.
Kg to lbs calculator
156.2 cm is 5 feet and 0.6 inches or about 5 ft 1 in
78 kg is 171.96 lb or about 172 lb
Here is the link to an online conversion calculator
http://www.infoplease.com/pages/unitconversion.html
The width and hieght of a tv screen which is 16:9 need to find the diagnol if it is 98 cm wide
.98/16 * 9 = .55125m = height tan? = .55125 / .98 ? = 29.357 cos ? = .98 / x x = .98 / cos ? x = 1.1244 m
1helpful
I want ro convert 5 feet4 inches into centimetress
To convert feet into cm: ft x 30.48 = cm
To convert inches into cm: in x 2.54 = cm
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
