I can not unlock my phone. i forgot my password. I tried the last four digits, called Verizon, and they told me to call my manufacturer-(samsung). I tried, but since my phone was locked, i could only...
You need to get a USB cable for your phone. I got one for under $3 delivered shopping on the net. You need to download & install the 4.4 Samsung USB Drivers, Google, they are free. You need to download, install & run a program called QXDM to get your MSL/SPC code. Then you download & install Samsung PSTLite v10004. Run that with your phone plugged into the USB port & turned on. Double click on your phone, then click on the PREPAID PHONE button, lower left, then READ ALL, at which point enter your code (you can try 998076 & see if its the same as mine was. After it is done reading your phone, you clock on the info button & you will get your two unlock codes for your phone. One of those will be the one you need.
I got this from another users post, kirbykirbykirby3, it is not mine, though I have added a little bit more information:
Here's how I find out the MSL/SPC from the U350, works with almost any phone.
QXDM, Connect it via Serial Port. (Com Port USB set to port 1, & 2)
Go to command output:
Type in Password "password 1945081520081106"
Without the quotes
Press Enter Key
then type in "requestnvitemread sec_code"
Without the quotes
Press Enter Key
there you go, security code right there.
You can also change anything you want... hehe.
Now boot up Samsung PSTLite, double click your phone U350, then click on 'Prepay' in the lower left corner, then click on read phone, then input the security code you got with QXDM for the 'Input MSL Code'. You can then click on info, settings, transfer, etc., make a backup of your address book, even edit it. I have not figured out how to get at the pictures with this method though. If you figure that one out, please post here as I am subscribed to this thread. Thank you.
need a new four digit code i dont kno the number or code
