SOURCE: HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
SOURCE: HP Printer Color LaserJet 2840
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
SOURCE: Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
