Televison & Video Logo
Jvc tv Vertical line (Top to bottom)about 2/3 of the way across the screen?
Anonymous
    Master:
  • 879 Answers
Horizontal output section has the fault. Check it. Replace horizontal output transistor.Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
Posted on May 20, 2013
4 Related Answers
Anonymous
  • 1284 Answers
SOURCE: line across top of screen
If the picture is ok otherwise then only thing that probably needs to be done is a vertical height adjustment. That is if the lines never changes position from cold to hot.
Posted on Feb 27, 2007
Anonymous
  • 346 Answers
SOURCE: thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Posted on Jan 17, 2009
Anonymous
  • 647 Answers
SOURCE: only thin white line across my toshiba tv
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Sep 28, 2009
Anonymous
SOURCE: Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Posted on May 23, 2010
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
1helpful
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
4helpful
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
2helpful
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
5helpful
3answers
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
1helpful
2answers
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jvc model av36230
you know its in vertical section, try to look for a capacitor and changed it, this is more of a capacitor problem.
Top Televison & Video Experts
Marvin
Marvin
