Canon MF4350d copier used to go into energy saver mode when idle, now it won't go into energy saver mode at all. I opened and closed the lid where you place pages for copying and that worked one time, now it s back to no energy saver mode .
SOURCE: energy saver mode
THIS CAN BE TURN OFF BY USING THE SETUP MODE, SEE THE MANUAL ON HOW TO ENTER SETUP MODE
SOURCE: Reset timer for energy saver mode
Every new unit comes with the user's manuals, and every new unit has free tech support from the vendor. What you are looking for is under the "System Settings" found after pressing "Additional Functions".
SOURCE: Do not know how to use the energy saver feature
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver button.
SOURCE: Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
SOURCE: alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
