Acer Aspire™ T180 PC Desktop Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It doesnt turn on.
I turn it on adn the power supply turns on running wide open and theres only one red light and no green light and then the power button wont turn it off i have to unplug it.
someone please help!!!!!!!!
Anonymous
Level 2:
  • Expert 72 Answers
  • Posted on Mar 18, 2009
Anonymous
Expert
Level 2:
Answers
72
Questions
0
Helped
17629
Points
143
Hi there, I would try replacing your power supply all together and see if this helps.
I have a tv set which doesnt work. when power on pilot light turns red then pressing the secondary power the pilot light turns green then turns red color immediately. it has a relay
Sounds like a power supply or switch problem.
Some switches have a brief contact made when turning on so this may be faulty or it could be the switch mode transistor that is borked.
2answers
AKAI 27" Wide-Screen LCD TV,
The tv is in protect mode, try first unplugging power cord for one hour, and see if this solve the problem.
Xbox 360 is flashing 3 red lights and doesnt play
Hello there.
Please click http://support.microsoft.com/kb/907534 to see about this problem.
As per the page:
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue: 1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Xbox 360: The power supply light is red 906102 (http://support.microsoft.com/kb/906102/) Xbox 360: The power supply light is orange 906103 (http://support.microsoft.com/kb/906103/) Xbox 360: The power supply light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again.If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support), and then click Console Repair? in the upper-right section of the Web page.
Hope this helps.
I have a Phillips Plasma Tv 42pf532 and suddendly turns off
Check its power supply regulator section. Look for any bulged capacitors. Replace them if any. It will be best to replace the power supply board as card basis, rather than making 'surgery' to it; especially to Plasma TVs. Most of the spare part it have, will be very difficult to get from open electronic spare part market.
Contact the nearest authorised service center for Philips to buy a new board.
Red light comes on hit power button green light comes on then turns off no picture or sound. power supply?
Usually power supply problem.If you want to open it yourself,then(unplug the unit first) unscrew the backpanel,get a clear two inch wide packaging tape.As you remove the screw tape it to where you got it so as not to loose them and know where they belong.Usually the power chord is connected to the power supply board.Observe any capacitors after the transformer(hot side do of the board)which have bulged top(usually 680 to 880nf/35 volts)but try to see the values cause they differ in brands,replace them with the same values.
Whenever i go turn the tv on its starts making a clicking noise.
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
From standby PS3 wont turn on.
that sounds like your main power supply unit
Tv doesnt turn on.
check the caps on power supply
TV turns itself off
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
2helpful
RED LIGHT
red light is shown when there is a problem with the power supply... the power supply may be short circuiting due to moisture or dust...
just open the power supply casing and clean it up..
if it does not work then the problem may lie with the components of the supply.. which can not be repairable if the power supply is not in front of me...
so you have to take it to a vendor
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
