Question about Dell Inspiron E1505 Notebook
My favorites on the tool bar is not there anymore,how do I get it
We had an ice storm Jan 27th the tower for my cable company went down and was down for a month. Now the favorites is not there and also some differrnt things are there. I also got e-mail that was not mine. I cannot go to favorite and get what I want, Help!
Posted by bcw4236 on
pontelemon
  • 538 Answers
Download THIS and scan.
Posted on Mar 18, 2009
Anonymous
    Sergeant:
  • 260 Answers
I went thru that ice storm as well. You should try doing a system restore on the PC to a point before the storm. If you need help with that we can assist you.
I need to know how to take the fuse box under the hood of my 2005 Chevy Impala so I can put a new one in.
Underhood Electrical Center or Junction Block Replacement
Removal Procedure
  1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
  2. Click to Enlarge
  3. Disconnect the positive battery cables from the underhood fuse block terminals.
  4. Remove the tape from the wiring harness at the base of the underhood fuse block base.
  5. Click to Enlarge
  6. Release the underhood fuse block(s) clip retainers using a small flat-bladed tool.
  7. Click to Enlarge
  8. Remove the fuse block(s) and wiring harness lifting up from the base and reposition from the base.
  9. Click to Enlarge
  10. Remove the nuts from the underhood fuse block base.
  11. Remove the underhood fuse block base from the shock tower.
  12. Click to Enlarge
  13. Remove the underhood fuse block lower front terminal positive assurance retainers using a small flat-bladed tool.
  14. Click to Enlarge
  15. Remove the plastic shields from the battery cable and buss bar terminals, using a small flat-bladed tool to release the clip retainer.
  16. Click to Enlarge
  17. Remove the bolts from the buss bar jumper bar.
  18. Click to Enlarge
  19. Remove the buss bar jumper bar from the fuse block(s).
  20. Click to Enlarge
  21. Remove the fuses from the fuse block(s) to access the buss bar terminal release tabs.
  22. Click to Enlarge
  23. Remove the buss bar(s) from the fuse block(s) using a terminal releasing tool, and pulling down and out on the buss bar.
  24. Click to Enlarge
  25. Remove the buss bar(s) from the fuse block(s).
  26. Click to Enlarge
  27. Release the clip retainers from the underhood fuse block(s) battery cable and buss bar terminals using a small flat-bladed tool.
  28. Click to Enlarge
  29. Remove the underhood fuse block(s) battery cable and buss bar terminals from the fuse block by pulling down.
  30. Remove the fuse block and lamp wiring harness from the vehicle, if required.
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
Jan 28, 2018 | Chevrolet Impala Cars & Trucks
HOW TO ADDA FAVOUTITES TAB ON IE 11 AS FOUND IN IE8
If you right-click in the toolbar area (at the top where the favorite bar USED to be) you will see a small pop up with a few options. Click "Favorites Bar" and that should do the trick.
Alternatively, while in IE press the ALT key one time to reveal the Menu Bar. Select View > Toolbars > Favorites Bar
Hope that helps! adda-favoutites-tab-ie-11-as-found-in-vqnzrvnqlx14j4uj04fm0vdy-3-0.jpg adda-favoutites-tab-ie-11-as-found-in-vqnzrvnqlx14j4uj04fm0vdy-3-2.jpg
Oct 13, 2014 | Microsoft Internet Explorer 8
How do I get google toolbar and not have ASK as my search engine ?
you can search the web for the 'google toolbar' and try to install it but you may have to use Google Chrome browser(install it from web) to use the google toolbar. why need that toolbar? you can attach google apps/tools to IE favorites bar, right? you don't have to use google search unless it is attached to the g tool bar?
Apr 24, 2014 | Microsoft XP Computers & Internet
How do i delete bookmarks
You bookmarks are on the left sidebar.
Your Favorites Bar is the second line down on Safari. You click on "View" then you can click hide or show the favorites bar.
You can edit the Favorites Bar by two finger clicking the touch pad or right clicking the (Non Apple) mouse.
You can also drag the link to the trash can to remove it.
To put another link in the favorites bar, click on the link in the tool bar and drag it to the favorites bar.
Apr 07, 2014 | Computers & Internet
Favourites is missing
Right click on the Tool Bar (any where below the URL window) and find Favorites on the popup-menu and select it/click on it and it will automatically check Favorites. Once that's done Favorites will show on your Tool Bar.
Apr 05, 2012 | Microsoft Windows XP Professional x64...
Links Unaccessible and Favorites Side Bar Gone
Had the same problem. Went to the IE8 home page (Microsoft). They are supporting IE8 at no cost until Dec 31. Wait time was minimal, tech took control of my computer and fixed the problem you described in a few seconds. Sorry, I do not remember the exact steps.
Mar 24, 2009 | Microsoft Internet Explorer 8
Tool bar for "Outlook Express" is not visable.
Try the below.
Go to View->Toolbars.
Once you place your mouse over it, You can select any/all of the toolbars as per your requirements.This should bring back your toolbar.
Rate the solution as Fixya!
tnx,
AD
Feb 26, 2009 | Insignia D300a PC Desktop
Picture changes from color to black & white after 5 minutes
This is probably a fault in the colour demodulator circuits. You would have to give the set to a properly equiped and experienced tech to service this for you.
Jerry G.
Jan 19, 2008 | Philips 26MF231D 26 in. LCD Television
Dell Inspiron E1505 Notebook Logo
216 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
