Question about Cell Phones
Phone problem Dropped my fone put in charger it and it won't load up only htc on screen and then it goes.took of the charger left it then turn it on it came on after a while it says low battery when I put in the charger it goes again
Posted by vonz on
Manni F. Bear
    New Friend:
  • 15 Answers
When you dropped your phone a wire inside of the phone must have snapped and disconnected the phone from the energy switch. I would take it to the company that supports your phone ex. LIME, Digicel Etc. I hope I help
Posted on May 20, 2013
I have an LG Optimus Regard Cricket phone and the touch screen suddenly stopped working. How do I fix it?
It's the charger screwing with the phone. Unplug it and I bet it works fine. Find a new charger.
Apr 11, 2013 | LG Optimus Black Smartphone
The phone won't turn on
Try replacing the rechargable battery inside that phone.
Jan 12, 2013 | HTC Amaze 4G Smartphone T-Mobile
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
HTC Vivid won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 04, 2012 | HTC Vivid
Cdm 8615 battery discharged...cant turn it off
pull battery out for 30 seconds and put back in, it should fix the problem.
here is a lin for u to read in a pdf
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiyyMLbh5nXAhVD22MKHWwEBpwQFggvMAE&url=https%3A%2F%2Fwww.cellcom.com%2Fresources%2Fmedia%2Fdocuments%2FUTSTARCOMcdm-8615-manual-1154.pdf&usg=AOvVaw0DtRprs1wAC6FOsJWHLI54
Oct 30, 2017 | Audiovox CDM8615VMC
Virgin Mobile LG Optimus V (vm670) won't load past LG screen
Yes there is hope You will need to flash over your phone try youtube or contact me if you need more help i will help you for a small fee.
Apr 23, 2012 | LG Cell Phones
My phone turned off randomly and now it won't turn back on,thinking it was dead I plugged it in using the USB charger because I lost the other one...but after plugging it in it still wouldn't turn...
First of all change your battery and try again if nothing happens don't do anything just go to service centre with a photocopy of purchasing bill.
Aug 04, 2011 | HTC Cell Phones
Nokia 1600 displaying local mode
didn't you try another battery?
Oct 16, 2008 | Nokia 6120
Cell Phones Logo
102 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
