Question about Nordic Track NordicTrack COMMERCIAL 1750 Treadmill
I plug in and turn on the switch and put on the cord but it does not come on,i did the reset,still does not come on
Posted by jonn adams on
ernesto cuadra
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
See the video and fix it. God bless you
Posted on May 24, 2013
Where is the reset button on a ED25SM Whirlpool refrigerator
refrigerators do not have a dedicated reset button, but you can, however, reset your refrigerator in the event of a technical problem.
resetting the main unit
  • 1 Turn the refrigerator's temperature control switch to "Off."
  • 2 Unplug the power cord.
  • 3 Plug the power cord back into the wall.
  • 4 Turn the control knob to adjust it to the temperature you want. leave cord unplugged for about 30 seconds. hope this helps ! good-day !
Dec 03, 2011 | Whirlpool Refrigerators
I have a proform 300 treadmill. we moved into a new home and it just stopped working. it was perfectly working before the move. now, nothing comes on, no power, nothing.
Dear Sir:
I will help you.
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
2) Circuit Breaker:
Please check the circuit breaker from the main panel, and reset, or put some Lamp for to see if turn on. if do it. the problem could be the wires and the plug, Test it with A VOM(Voltimeter) for a continuity.
Thank you in advance, sincerely.
If you need extra help, please do not hesitate to reach me. .
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Proform 810 TR Treadmill
Need Some Help, My Psp 3001, Turns Off On It's Own, While I'm Playing A Game Or Listning To Music, What can i do???
Here are some instruction to help fix your problem.
Put the PSP down on a table with the LCD screen facing up.
  • 2 Plug the power cord of the PSP power supply into the PSP's power outlet. Plug the AC plug of the PSP power supply into an AC socket.
  • 3 Perform a hard reset on the PSP by pushing up on the power switch at the lower-right corner with your index finger.
  • 4 Count to 15. Release the PSP's power switch. Count to 30.
  • 5 Flick the PSP's power switch up with your index finger and release it. Repeat this procedure a second time.
  • 6 Wait as the PSP reboots, starts up and stays on.
  • 7 Remove the PSP power supply's power cord from the PSP's power outlet. Remove the PSP power supply's AC plug from the AC socket.
  • 8 Flick the power switch up with your index finger to turn off the PSP.
  • May 04, 2011 | Video Game Consoles & Games
    I have a Hoover Mach 2.7 Windtunnel that shut off during use and wouldn't turn back on. Was doing kitchen floor and running fine. Though a breaker tripped but didn't...what could it be?
    It sounds like your thermal reset switch inside of your Hoover may have gone bad. When a vacuum cleaner doesn't turn on it, it's either caused by one of four things.
    1. Electrical Short in your Cord.
    2. Plug has gone bad.
    3. Motor of your vacuum is faulty
    4. The On / Off Switch has gone bad, and/or your Thermal Reset Switch has gone bad
    Since this happened while you were vacuuming, I would guess that this is either your electrical plug that's shorted out, or that your thermal reset switch has shorted out. Your model Hoover was built with a protection system that is supposed to automatically shut down your machine if it senses any excessive heat. This mechanism is controlled by a Thermal reset switch which is located in motor compartment. This part is notoroious for failing, even when there's no overheating that's occured.
    Before you disassemble the entire machine to check this part though, I would try testing the On / Off switch in your machine, as well as testing the electrical cord, which will also let you know if your plug has gone bad.
    Here's a link to a solution I've done here on FixYa explaining how to check the On / Off switch;
    http://www.fixya.com/support/r4530569-replace_off_switch_hoover_windtunnel
    While you have this apart, you can use the same electrical tester to test your cord. Simply put one end of the test into the terminal from the switch, and the other end of the test on one of the metal prongs that plugs into the wall. See if you have continuity here, if not, switch to the other prong of the plug and see if this helps.
    If not continuity, this means your plug, or your cord has failed. If you do have continuity, this means that it's either the On / off switch, or the Thermal Reset Switch that's gone bad.
    Here's a link to the solution that I've done on here showing how to replace the Thermal Reset Switch on your vacuum cleaner:
    http://www.fixya.com/support/r4999778-replace_thermal_overload_switch_hoover
    If you'd like some more help diagnosing this vacuum, please feel free to just use the comment field on the bottom of this page. I'm always happy to help you do some more advanced diagnosing, or answer any questions you may have.
    If you found this solution helpful, please be so kind and rate this repair helpful, or leave feedback for me. This is greatly appreciated by the FixYa community. Thanks so much,
    Chris Jones
    GoVacuum.com
    Jan 10, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
    The vacuum was on when my son tripped the cord and one prong broke off in the outlet. We patched on another cord. It won't turn on tried other outlets. Can't find reset switch, is there one or did we...
    Maybe you got the wires crossed between the two cords. Vacuums have polarized plugs and if wired imcorrectly can definitely cause the vacuum to not work. Try switching over.
    In other words, consider current wires as A1/A2 and B1/B2. Disconnect, then connect A1 to B2 and A2 to B1.
    vacuum===============A1 A2=======Plug
    ===============B1 B2=======Plug
    Switch to
    vacuum===============A1 B2=======Plug
    ===============B1 A2=======Plug
    Try this and see what happens.
    Jan 03, 2011 | Dyson DC14 All floors Bagless Upright...
    We just bought the floor model of the weslo cadence 58 treadmill and it wont work, we have the key, but it is not working. is there a switch we should be turning on to get it to work?
    Plug in the power cord . Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then put your safety key and it should start up for you.
    May 03, 2010 | Weslo Cadence Ct 5.8 Treadmill
    How do I turn off my Reebok 8050 ES? I can not figure out how to turn it off when I am not using it.
    Plug in the power cord. Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset
    Apr 20, 2010 | Reebok 8050 ES Treadmill
    My HP 2175 printer keeps giving me the message to align the print cartridges. will not copy or anything
    Hello sir; Your machine need to reset; turn power on, open the cover when cartridge carrier move to the center ,the UNPLUG the power cord wait about a minute put power switch in off position, then plug in power, turn switch on.
    Nov 22, 2009 | HP PSC 2175 All-In-One InkJet Printer
    Readoout says
    1. Turn machine OFF and unplug electrical cord from wall or power strip.
    2. Turn ON printer without the power cord plugged in (this will discharge the power capaciter in the printer).
    3. Plug electrical power back in and turn on printer...
    4. It should have reset.
    Another possibility:
    The scanner arm has the physical "lock" switch in the locked possition. Turn OFF printer and move the switch to the unlock position. Turn on printer.
    This switch is for whenever the printer is moved to a different location and will protect the scanning bar.
    Hope this helps!
    Sep 09, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
    Battery Won't Charge
    Hey Guest9,
    You can try resetting the camera by removing the memory card and the battery, pushing a straightened paperclip into the reset switch inside the battery compartment, and reinstalling the battery. If this works put the memory card back in. Another option you have is to try formatting the memory card.
    Sincerely,
    Allan
    Go Ahead. Use Us.
    Apr 16, 2008 | HP Photosmart R727 Digital Camera
    Nordic Track NordicTrack COMMERCIAL 1750 Treadmill Logo
    160 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Marvin
    Marvin
    Jesse Garza
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
